Problem using the solidificationMeltingSource fvOption with compressibleInterFoam
Old   July 18, 2017, 05:54
Default Problem using the solidificationMeltingSource fvOption with compressibleInterFoam
Katana
waterbender is on a distinguished road
Hello everyone!
I am trying to simulate Stefan's problem with an compressible air gap on top.
I included the fvOptions 'solidificationMeltingSource' for simulating the melting in the solid/liquid part which I set using . But for some reason, the entire domain gets filled with the solid/liquid part and there is no more air on top.
I tried to implement it the way it was done here for Gallium melting: Tutorial/functional case for solidificationMeltingSource
When I run the solver after I run setFields and topoSet, there is no more metal melting fraction (sMS1:alpha1) in the solved timesteps folders which I think indicates that the fvOptions is not active for some reason.
I am new to OpenFOAM and I am not sure what I am doing wrong.
Thanks
waterbender is offline   Reply With Quote
melting, openfoam, stefan problem
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
