New Model of Turbulence with Porosity Source Term
Old   July 17, 2017, 06:25
Default New Model of Turbulence with Porosity Source Term
Chus Mat
chusma is on a distinguished road
Hello everyone,
I am trying to include a source term in the k-epsilon model. The source term is related with the porosity applying the Darcy-Forchheimer Law.
I have created a Field called Darcy which my program will read. With that field I calculate other two terms.
There are not compilation errors, however when I launch porousSimpleFoam the following error occurs:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted
Despite I have not created any new pointer to the functions the error still appearing.
Somebody could help me with this? I will appreciate any help.
Here is how I define the functions in my code:
tmp<volScalarField> kEpsilonFurow :: permeability()//New
volScalarField permeability_("permeability", porosity()/Darcy_);
return permeability_;
tmp<volScalarField> kEpsilonFurow :: porosity()//New
volScalarField porosity_("porosity", sqrt(1/(0.00450799*Darcy_ +1 )));
return porosity_;
tmp <volScalarField> kEpsilonFurow ::Gk()//New
volScalarField Gk("Gk", Ck_*k_*porosity()/sqrt(permeability())* sqrt(U_ & U_) );
volScalarField Zero("Zero", 0.0*k_);
if (Darcy_ > Zero)
return Gk;
else
return Zero;
And in the k equation:
tmp<fvScalarMatrix> kEqn
fvm::ddt(k_)
+ fvm::div(phi_, k_)
- fvm::laplacian(DkEff(), k_)
G + Gk()
- fvm::Sp(epsilon_/k_, k_)
chusma is offline   Reply With Quote
Old   February 11, 2021, 14:25
Agustín Villa
agustinvo is on a distinguished road
I know it's been a while, but did you find an answer to this issue? I'm facing a similar problem. I have a function which returns a tmp field, but if I create the field inside the function I get also this error message when running.
agustinvo is offline   Reply With Quote
code, compilation, porosity, poroussimplefoam, turbuelence model
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
