July 1, 2017, 00:28 |
MPI error in parallel application
Rep Power: 11 |
Hello Foamers,
I have coded a utility application capable of running in parallel. I tested it on my laptop (4-8 cores) and also in a cluster (48-96 cores). It was able to run successfully all the time. Recently, I tried to run it on a mesh using 96 cores but it keeps crashing with the following error: Code:
[45] [93] [93] [93] --> FOAM FATAL IO ERROR: [93] wrong token type - expected int, found on line 0 the word 'x' [93] [93] file: IOstream at line 0. [93] [93] From function operator>>(Istream&, int&) [93] in file primitives/ints/int/intIO.C at line 68. [93] FOAM parallel run exiting [93] [87] [88] [88] [88] --> FOAM FATAL IO ERROR: [88] wrong token type - expected int, found on line 0 the word 'x' [88] [88] file: IOstream at line 0. [88] [88] From function operator>>(Istream&, int&) [88] in file primitives/ints/int/intIO.C at line 68. [88] FOAM parallel run exiting [88] [45] [92] [92] [92] --> FOAM FATAL IO ERROR: [92] wrong token type - expected int, found on line 0 the word 'x' [92] [92] file: IOstream at line 0. [92] [92] From function operator>>(Istream&, int&) [92] in file primitives/ints/int/intIO.C at line 68. [92] FOAM parallel run exiting [92] [94] [94] [94] --> FOAM FATAL IO ERROR: [94] wrong token type - expected int, found on line 0 the word 'x' [94] [94] file: IOstream at line 0. [94] [94] From function operator>>(Istream&, int&) [94] in file primitives/ints/int/intIO.C at line 68. [94] FOAM parallel run exiting [94] [95] [95] [95] --> FOAM FATAL IO ERROR: [95] wrong token type - expected int, found on line 0 the word 'x' [95] [95] file: IOstream at line 0. [95] [95] From function operator>>(Istream&, int&) [95] in file primitives/ints/int/intIO.C at line 68. [95] FOAM parallel run exiting [95] [89] [89] [89] --> FOAM FATAL IO ERROR: [89] wrong token type - expected int, found on line 0 the word 'x' [89] [89] file: IOstream at line 0. [89] [89] From function operator>>(Istream&, int&) [89] in file primitives/ints/int/intIO.C at line 68. [89] FOAM parallel run exiting [89] [90] [90] [90] --> FOAM FATAL IO ERROR: [90] wrong token type - expected int, found on line 0 the word 'x' [90] [90] file: IOstream at line 0. [90] [90] From function operator>>(Istream&, int&) [90] in file primitives/ints/int/intIO.C at line 68. [90] FOAM parallel run exiting [90] [91] [91] [91] --> FOAM FATAL IO ERROR: [91] wrong token type - expected int, found on line 0 the word 'x' [91] [91] file: IOstream at line 0. [91] [91] From function operator>>(Istream&, int&) [91] in file primitives/ints/int/intIO.C at line 68. [91] FOAM parallel run exiting [91] [45] --> FOAM FATAL IO ERROR: [87] [87] --> FOAM FATAL IO ERROR: [87] wrong token type - expected int, found on line 0 the word 'x' [87] [87] file: IOstream at line 0. [87] [87] From function operator>>(Istream&, int&) [87] in file primitives/ints/int/intIO.C at line 68. [87] FOAM parallel run exiting [87] [45] wrong token type - expected int, found on line 0 the word 'x' [45] [45] file: IOstream at line 0. [45] [45] From function operator>>(Istream&, int&) [45] in file primitives/ints/int/intIO.C at line 68. [45] FOAM parallel run exiting [45] [std0741:29931] 9 more processes have sent help message help-mpi-api.txt / mpi-abort [std0741:29931] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages I'll be glad to provide any additional details. Many thanks, USV |
August 1, 2017, 01:34 |
Rep Power: 11 |
Dear Foamers,
I have not managed to figure out the problem yet. As you can see, it says error in "IOstream" which I am certain refers to the IPstream from which it is supposed to receive some data. The perplexing thing is that there was no problem running this program on 48 cores. It happens when I increase the number of cores to 192. Code:
[119] --> FOAM FATAL IO ERROR: [119] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) [119] [119] file: IOstream at line 0. [119] [119] From function IOstream::fatalCheck(const char*) const [119] in file db/IOstreams/IOstreams/IOstream.C at line 114. [119] FOAM parallel run exiting Many thanks, USV |
September 14, 2017, 12:30 |
Lento
I am facing a similar issue.
What I noticed is that it also depends on the decomposition approach. If I use 'simple' it works by not with a 'scotch' approach. So far, I don't know what is the source of the error. |
error, mpi, parallel |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 13:36 |
MPI application rank 0 exited before.. | jypark | FLUENT | 1 | July 15, 2016 13:58 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 20:05 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
