Having difficulties with coupling interFoam with Level Set method |
June 21, 2017, 07:41 |
Nguyen Duy Trong
Rep Power: 12 |
Hi everyone,
I am coupling interFoam vs Level Set (LS) method. The coupling manner is followed by tutorial of Sankar Menon at: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/ for the first step, if I only care about the surface tension (sclsVOFsf solver), it can done quite well. However, when I take into account correction of density and viscosity (sclsVOF solver) it requires declaration of Heaviside function H in fvOption. I guess H and alpha.water are similar then I declared they are same solver. However, it crashed as in the attached file. It would be appreciate if someone could help me solve this problem. Thank you in advance. |
October 4, 2017, 04:58 |
error in Couple Level Set with VOF interFoam
Nguyen Duy Trong
Rep Power: 12 |
Dear Foamers,
I am trying to recompile the sclsVOFFoamsf of Dr. T. Yamamoto for OpenFoam v5. Compilation seems good and solver can run for few step, however, I got the errors as follows: [4] #0 [5] [3] #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) at ??:? at ??:? [3] #1 [5] #1 Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHand ler(int) at ??:? [4] #1 Foam::sigFpe::sigHandler(int) at ??:? [4] #2 ? at ??:? [5] #2 ? at ??:? [3] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [4] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6" [5] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [4] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? [3] #4 at ??:? [4] #5 at ??:? [5] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)?Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? [3] #5 at ??:? [5] #5 at ??:? [4] #6 __libc_start_main?? in "/lib/x86_64-linux-gnu/libc.so.6" [4] #7 at ??:? [5] #6 __libc_start_main at ??:? [3] #6 __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6" [5] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 ? at ??:? It would be appreciate if someone could help me to fix this error. The log file of solver is as in the attached file. Thank you |
October 7, 2017, 08:32 |
sandy
Rep Power: 10 |
plz give more information regarding where did you get the code of sclsvofsf and what changes have you made in order to upgrade it to compile it on openfoam 5.
i encountered similar problems while recompiling evapvofhardt solver. it happens so that compiling successfully and running successfully are two different things |
October 9, 2017, 13:09 |
#4 | |
Nguyen Duy Trong
Rep Power: 12 |
I changed values of cAlpha and maxDeltaT and it can run well. Thank you so much for your comment |
October 13, 2017, 04:44 |
Sumeet Sambhus
Dear Nguyen,
I am new to Openfoam and want to solve problems using CLSVOF solver. Could you please provide your solver ? Thanks in advance! regards, Sumeet. |
October 18, 2017, 04:39 |
sandy
Rep Power: 10 |
here's the link to solver and report + presentation
www.tfd.chalmers.se/~hani/kurser/OS_CFD/ ctr+f: sankar menon |
October 18, 2017, 06:36 |
Sumeet Sambhus
Thanks sandy.
January 21, 2018, 18:45 |
Yuanwei Cao
Rep Power: 9 |
Hi, have you tested the sclsvofFoam solver? Such as dambreak, rum in parallel?
setting of level set method as initial condition | sooroo3 | FLUENT | 4 | July 31, 2018 05:20 |
Level set method---reinitiallization and boundary conditions | wenxu | OpenFOAM Running, Solving & CFD | 2 | February 28, 2018 12:43 |
Level Set Method - OpenFOAM-1.5-dev | Ingenierias2003 | OpenFOAM | 2 | August 7, 2012 05:36 |
calculating Normal vector in level set method | amir2920 | Main CFD Forum | 1 | July 21, 2009 08:25 |
Level set method for detonation | Amir | Main CFD Forum | 1 | July 2, 2008 16:25 |
