June 4, 2017, 20:16 |
Sudo bash, Implementation a new solver
Lieh
Rep Power: 9 |
Hello
I am implementing my own solver, for that, I pick an already implemented solver in OF and do all the procedures mentioned on the threads. At the step when I need to do wmake, it does not work, so then I have to do sudo bash first then do wmake, and doing this, wmake works. When I test the solver, it seems that again I need to be in the condition of sudo bash, otherwise solver is not recognized. Having used sudo bash, then the solver works perfectly, and runs. Is there any way to have the solver working in normal condition? not necessarily having already sudo bash on? Thanks for your help in advance |
June 5, 2017, 05:01 |
W.T
Rep Power: 13 |
Sound like you try write solver to OpenFoam main directory.
Did you edit the Make/files of new solver i way that new solver will be located in $FOAM_USER_APPBIN instead of $FOAM_APPBIN ? |
June 5, 2017, 18:49 |
Lieh
Rep Power: 9 |
Yes I do that, and the solver is located in user appbin!
new solver, openfoam 4.1, wmake problems |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Understanding conjugate solver implementation in openfoam | umeshisode | OpenFOAM Programming & Development | 0 | February 9, 2015 06:17 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Puzzled by multi-block solver implementation...... | Chen Zhi | Main CFD Forum | 3 | February 14, 2010 20:10 |
