Problem in compiling the makeAxialMesh utility
Old   May 23, 2017, 05:38
Default Problem in compiling the makeAxialMesh utility
Mario Belmar
Belmar is on a distinguished road
Hi everybody,
I'm new in OpenFoam and I'm having some problems in the compilation of the mesh utility called makeAxialMess. I have installed Foam Extended 3.2 so I downloaded A tar with the sources that work for 2.x.from http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh. The problem is when I execute wmake or ./Allwmake in the directory (I saved the folder in utilities/mesh/manipulation) the following message error appears:
SOURCE=makeAxialMesh.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DFOAM_DEV -I/home/mabelgi1/foam/foam-extend-3.2/src/dynamicMesh/lnInclude -I/home/mabelgi1/foam/foam-extend-3.2/src/dynamicMesh/dynamicMesh/lnInclude -I/home/mabelgi1/foam/foam-extend-3.2/src/cfdTools/lnInclude -I/home/mabelgi1/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/home/mabelgi1/foam/foam-extend-3.2/src/foam/lnInclude -I/home/mabelgi1/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeAxialMesh.o
makeAxialMesh.C:52:18: fatal error: Time.H: No such file or directory
#include "Time.H"
compilation terminated.
I would really appreciate any kind of help. Thanks.
Belmar is offline   Reply With Quote
Old   July 18, 2017, 16:17
Default I know this is an old thread...
Nate
ndev is on a distinguished road
...but to anyone coming across this in the future, the include statement for "Time.H" must be replaced with "foamTime.H" in order for this to compile!
ndev is offline   Reply With Quote
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 06:32
Sample utility - file name indexing problem sepponen OpenFOAM Post-Processing 0 July 28, 2016 07:58
problem compiling spalart allmaras model bababanamzdaalma OpenFOAM 0 April 4, 2012 21:13
Compiling problem with VS2005+Intel C++ 11 about operator()() overloading zouchu OpenFOAM Installation 0 February 7, 2012 18:19
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 15:44
