introducing non-linearity|how to access the underrelaxed p-values |
May 16, 2017, 13:05 |
Tom Dylan
Rep Power: 11 |
Hi foamers,
I'd like to expand the capabilities of a solver for coupled flow-deformation in porous media in order to consider unsaturated flow conditions. The problem consist of a diffusion-type equation for pore pressure p and an momentum equation for the displacement U that are handled in a segregated manner (see the code sniplet). Under unsaturated conditions the coefficients Dp and Dp2 depend on the pressure, so the whole system gets a bit more non-linear. The "clean" way would be to evaluate p in a inner iteration loop (Picard iteration?) and then after convergence to pass over grad(p) to the momentum equation. Since pEqn receives a kind of "lagged" contribution fvc::div(fvc::ddt(Dp2,U)) from U.Eqn and exibits therefore some linearity which is handled in the iteration loop I wonder if just updating the Dp and Dp2 coefficients within the existing iteration loop would be a good idea. For this I need the values of the underrelaxed p-field. Is there a way to access the under-relaxed p-field values after p.relax() in order to evaluate the p-dependent coefficients according to the corresponding relaxed p-values? Code:
do { p.storePrevIter(); fvScalarMatrix pEqn ( fvm::ddt(p) == fvm::laplacian(Dp, p) - fvc::div(fvc::ddt(Dp2,U)) ); pResidual = pEqn.solve().initialResidual(); p.relax(); U.storePrevIter(); fvVectorMatrix UEqn ( fvm::d2dt2(rho, U) == fvm::laplacian(K, U, "laplacian(DU,U)") + fvc::div(sigma) - fvc::div(K & gradU) - fvc::grad(p) ); UResidual = UEqn.solve().initialResidual(); U.relax(); gradU = fvc::grad(U); # include "calculateSigmaEpsilonOrtho.H" initialResidual = max(pResidual,UResidual); if (iCorr % 1 == 0){ Info << "\tTime " << runTime.value() << ", Corrector " << iCorr << ", Solving for " << U.name() // << " using " << solverPerf.solverName() << ", residual = " << initialResidual << endl; } } while (initialResidual > convergenceTolerance && ++iCorr < nCorr); |
flow-deformation, non-linearity, porous media, unsaturated flow |
access node values in UDFs | Amir | FLUENT | 4 | September 29, 2022 11:16 |
access node values in UDFs | Amir | Fluent UDF and Scheme Programming | 0 | February 6, 2011 16:15 |
how to access stored values og gradients of scalars in star ccm | imamazaidi | STAR-CCM+ | 0 | January 7, 2010 17:33 |
Access Field values at certain time | andrea | OpenFOAM Running, Solving & CFD | 0 | August 31, 2009 07:24 |
Accessing Values of U_general questions | harly | OpenFOAM | 3 | December 8, 2008 15:14 |
