Problem in compiling a solver made for a different version (v2.0 ->v4.1)
Old   April 27, 2017, 07:20
Default Problem in compiling a solver made for a different version (v2.0 ->v4.1)
JLS
Jaime
JLS is on a distinguished road
Hi, I am new in the Forum and in OpenFOAM. I am working on an academic project and I need to compile a solver in version 4.3 that was originally made for version 2.0 (I am not sure about this, but it should be from version 2.0 to version 2.3).
After some debugging, I only have one error that I am not able to solve.
This is de error message:
pEqn.H:26:5: error: no matching function for call to ‘setSnGrad(const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary&, Foam::tmp<Foam::FieldField<Foam::fvsPatchField, double> >)’
This is the code related to the error message:
setSnGrad<fixedFluxPressureFvPatchScalarField>
p_rgh.boundaryField(),
phiHbyA.boundaryField()
- (mesh.Sf().boundaryField() & U.boundaryField())
)/(mesh.magSf().boundaryField()*rAUf.boundaryField() )
Apologize me in advance if the way of posting is inappropriate, I carefully read the rules and I posted the way I understood I should.
Thank you for your answers and plese be as clear as possible, I am really noob in OpenFOAM.
Thank you
JLS is offline   Reply With Quote
Old   May 8, 2017, 13:45
JLS
Jaime
I already solved it. I will answer my own question in case somebody else is working on adapting a solver of an old version into a newer OpenFOAM version (at the time of this post the latest is 4.1)
It looks that after OpenFOAM 2.3 (or 2.4, I am not sure) to update the fixedFluxPressure BCs (and I guess it should be similar for other kinds of BCs) you change the code that I showed before for this simple line:
constrainPressure(p_rgh, U, phiHbyA, rAUf);
Hope it helps someone.
Old   July 9, 2019, 15:03
Akhalesh sharma
Akhalesh123 is on a distinguished road
Hello Sir
I am facing the same problem. I am using Open FOAM 5x but solver is of 3.01.Same error I am getting. Can you resolve my issue?Thanks in advance.
Akhalesh123 is offline   Reply With Quote
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
solver stop problem in Lagrangian Particle Tracking sakurabogoda CFX 3 October 5, 2012 07:09
Problem with implicit unsteady solver CCMuser STAR-CCM+ 2 March 3, 2010 12:20
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 11:21
