request for volScalarField k from objectRegistry region0 failed+(DPMFoam) |
April 9, 2019, 06:47 |
request for volScalarField none from objectRegistry region0 failed (ReactingFoam)
#41 |
Malini Dasgupta
Rep Power: 7 |
Hello everyone,
Thanks for this thread. I hope I am able to give good description to my problem. So here goes: My geometry is a simple wedge with an angle of 36 deg and a bore of 1.6 mm dia at the center here is a link to my case which includes a log file of the checkMesh and the reactingFoam that I tried to run as well https://drive.google.com/open?id=1NM...eQ4gOWIy2I-Kkj I try to achieve mixing of HMDSO+N2 with the incoming gaseous stream in the reactor. For simplicity i have assigned cylic conditions to the wedge boundaries as I plan to simulate only a part of a cylindric reactor (in the form of wedge) However I get the following error when I run reactingFoam: --> FOAM FATAL ERROR: request for volScalarField none from objectRegistry region0 failed available objects of type volScalarField are 29 ( H2O_0 thermo:mu HMDSO_0 thermosi nut N2 K K_0 CO2_0 h rho CO2 k h_0 Qdot (1|A(U)) dpdt Ox_0 Ox PaSR<psiReactionThermo>:kappa thermosi_0 alphat HMDSO rho_0 p T H2O epsilon thermo:alpha ) Can someone please guide me as to where I am going wrong here? (PS: I am very new to OpenFoam) |
January 7, 2020, 14:14 |
same Problem with DPMFoam
#42 | |
Rep Power: 7 |
hi everbody,
i have the same error massage, but my problem is, that there is no thermosi field in my simulation. Also there is no folder or file with this name. Quote:
Thanks a lot |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 04:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 16:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 10:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
