Using a plane averaged field in the momentum equation |
April 20, 2017, 15:37 |
Santiago Lopez Castano
Rep Power: 16 |
Hi foamers,
so im currently getting my head around stratification in channel flows and I wanted to modify a solver I'm currently working on. The problem is that at some point in the iteration I would like to determine the fluctuation of density equal to the difference between the density field and its average over the horizontal plane. I guess I could do a forAll cycle for each horizontal plane, create a volScalarField and save that same value for all cells with that specific height, but I find the method a bit rudimentary; Is there a cleaner way it could be done? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
viscosity term in discetrization momentum equation | hans-186 | Main CFD Forum | 4 | April 1, 2013 14:34 |
Coefficients discretized momentum equation | michujo | Main CFD Forum | 4 | June 20, 2012 02:33 |
Momentum equation of Darcy's law | sambatra | OpenFOAM Running, Solving & CFD | 2 | April 17, 2009 04:27 |
Coupling between momentum and energy equation | Mattia | FLUENT | 0 | October 26, 2007 09:02 |
