creating an unsteady coupled solver
Old   March 31, 2017, 10:40
Default creating an unsteady coupled solver
Mohammad
m2montazari is on a distinguished road
I'm somewhat newbie in foam. I wanted to have a solver for unsteady coupled solver with variable density. I started with foam-extend-4.0 and simply edited pUCoupledFoam solver. At the first step, I tried to add time derivative. So added
 + fvm::ddt(U)
in UEqn.H and compile it to a new solver name, say "unsteadypUCoupledFOAM". But the result is an unstable solver which diverges for a simple starting poiseuille flow(which icoFoam doesn't have any trouble in convergence).
where is my fault? should I change any other things?
Also is there a better choice instead of pUCoupledFoam to start from?
thanks in advanced...
UPDATE:
I decided to check a more simple test case. So I ran first stockes problem (suddenly moving plate in semi-infinite domain). I overcame on the unstability by lowering timestep and using upwind scheme.
Now the problem is that icoFoam results are in good agreement with analytical solution; but unsteadypUcoupledFoam has some errors and do not fit on analytical solution.
I tried to extract rUA from convective-diffusive terms without time derivative term; but it almost doesn't change the results.
m2montazari is offline   Reply With Quote
foam-extend-4.0, pucoupledfoam, unsteady
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
pressure-based coupled solver for compressible NS equation wangmianzhi Main CFD Forum 19 July 29, 2016 04:37
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 20:41
convergence of density-based solver for unsteady flow zhengjg FLUENT 0 June 16, 2014 11:16
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 19:06
