fvMatrix solve and the updating of Fields
Old   March 15, 2017, 19:51
Default fvMatrix solve and the updating of Fields
Basel Abu-sinni
BaselAS is on a distinguished road
I've been digging through the documentation for a couple of days, I've yet to discover how or where field gets updated with new values after each iteration.
For instance in Laplacianfoam, how is the temperature field T gets updated after the fvMatrix TEqn is solved?
My intent is to override this stage and plug in my own solution to replace T.
Thanks in advance!
Basel
[EDIT] SOLVED: T[i] = val;
BaselAS is offline   Reply With Quote
Old   March 16, 2017, 15:24
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Then you don't need to solve the matrix equation at all. Just use your own values for T.
Zeppo is offline   Reply With Quote
Old   March 16, 2017, 15:58
Basel Abu-sinni
Yes, how do I do that inside a simple.loop?
I apologize I am barely even considered a beginner in OF
Old   March 23, 2017, 08:30
Santiago Lopez Castano
Santiago is on a distinguished road
You want to give an initial field? Or you want to give a prescribed field? What's the point of using laplacianFoam if ypu already know T?
Sent from my GT-I8190L using CFD Online Forum mobile app
Santiago is offline   Reply With Quote
Old   March 23, 2017, 09:51
Basel Abu-sinni
I apologize I haven't been clear with my purpose:
I'm using an external solver to solve the system, the solution I get in this case should replace the values of the temperature field T.
Anyway, the issue is solved, it's as simple as T[i] = solution[i]
Thank you both for your replies
fields, fvmatrix, solve, update
