Matrix addressing
Old   March 13, 2017, 15:50
Default Matrix addressing
Basel Abu-sinni
BaselAS is on a distinguished road
I'm very new to OpenFOAM, and I've been tasked in exporting a certain matrix's data from the solver on each time-step.
I've read Matrices_in_OpenFOAM but unfortunately I didn't fully understand lduaddressing... where can I find more examples on the subject?
as I mentioned, I need to export the matrix's data, meaning I need to loop over all non-zero entries and output the value along with its row-col index. any tips are very much welcomed.
Thanks in advance,
Basel
BaselAS is offline   Reply With Quote
Old   March 14, 2017, 11:23
Hasan Shetabivash
hasan_shetabivash is on a distinguished road
Dear BaselAS,
LduAddressing keeps the addressing of related cells. In lduMatrix coefficients are stored in three list named diagonal, upper and lower. If you just want to export the fvMatrix data you can simply use << operator for those list. And if you want to have indexing of all the lists you need to loop over all faces. The following example may help you.
  fvScalarMatrix TEqn
        fvm::ddt(T)+
        fvm::laplacian(dimensionedScalar("D", dimensionSet(0,2,-1,0,0,0,0), 1), T)
//Printing diagonal lower and upper lists
    Info<<TEqn.diag()<<endl;
    Info<<TEqn.lower()<<endl;
    Info<<TEqn.upper()<<endl;
    const labelUList& owner = mesh.owner();
    const labelUList& neighbour = mesh.neighbour();
    Info<<owner<<endl;
    Info<<neighbour<<endl;
    const labelUList& lowerAdd = TEqn.lduAddr().lowerAddr();
    const labelUList& upperAdd = TEqn.lduAddr().upperAddr();
    for(int index=0;index<mesh.cells().size();index++)
        Info<<"Diagonal value"<<TEqn.diag()[index]<<"\tDiagonal index: "<<index<<","<<index<<endl;
    forAll(neighbour, facei)
        Info<<"Lower value: "<<TEqn.lower()[facei]<<"\tLower index: "<<upperAdd[facei]<<","<<lowerAdd[facei]<<endl;
        Info<<"Upper value: "<<TEqn.upper()[facei]<<"\tUpper index: "<<lowerAdd[facei]<<","<<upperAdd[facei]<<endl;
Cheers,
hasan_shetabivash is offline   Reply With Quote
Old   March 14, 2017, 13:11
Basel Abu-sinni
Originally Posted by hasan_shetabivash View Post
Dear BaselAS,
  fvScalarMatrix TEqn
        fvm::ddt(T)+
    Info<<owner<<endl;
    for(int index=0;index<=neighbour.size();index++)
Cheers,
That's fantastic, exactly what I needed!
Thank you very much!
addressing, export data, matrix
Matrix addressing maybee OpenFOAM Programming & Development 10 August 1, 2020 08:55
ldu matrix, ldu addressing maybee OpenFOAM Programming & Development 0 December 7, 2013 13:40
Force can not converge colopolo CFX 13 October 4, 2011 23:03
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 22:47
Addressing matrix element and reuse of system matrix marziolettich OpenFOAM Running, Solving & CFD 2 February 19, 2008 06:04
