#21 |
Tobias Holzmann
Rep Power: 51 ![]() ![]() ![]() |
The derivation I showed above is not 100% correct.
The most important thing is how you define your enthalpy - which is a function of (in most cases) T and p. If the p derivative can be neglected it is very easy because ![]() More informations are given in my Ph.D. (unfortunately German and not yet published) or in the book of Moukalled et al.
Keep foaming, Tobias Holzmann |
#22 | |
Karelke Yu
Rep Power: 11 ![]() |
Could u pls give some hints (or post your new results) about how your 5 temperature implementations work and their performance? May I also take a look at your fvSchemes setting? If you used temperature dependent cp, rho and k, where did you update their values? |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 18:00 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
temperature equation for one phase in multiphase solver | romant | OpenFOAM Programming & Development | 0 | April 13, 2010 05:06 |
Adding temperature equation in settlingFoam | sachin | OpenFOAM Running, Solving & CFD | 2 | March 31, 2010 03:21 |
