Snippet for redefining fixedGradient boundary condition for a patch inside solver |
May 27, 2017, 12:08 |
#21 | |
Philip Cardiff
Rep Power: 34 |
You can manually apply under-relaxation when setting the boundary conditions e.g. Code:
// No under-relaxation //gradcMinusField = cMinus.boundaryField()[patchI] * Ue.boundaryField()[patchI].snGrad() + DcinfLinv * 3.68e-14; // With under-relaxation const scalarField newGrad = cMinus.boundaryField()[patchI] * Ue.boundaryField()[patchI].snGrad() + DcinfLinv * 3.68e-14; const scalar relaxFactor = 0.1; gradcMinusField = relaxFactor*newGrad + (1.0 - relaxFactor)* gradcMinusField; Philip |
May 27, 2017, 17:58 |
#22 |
Bobby
Rep Power: 16 |
Thanks Philip
The idea of coupled solver (coupling these 3 equations before pimple loop) is interesting for me too. I found out that Foam-Extend has some coupled solver examples. I will proceed through BC under-relaxation and coupled solver. Lets see how they perform. Regards |
June 2, 2017, 22:51 |
#23 |
Bobby
Rep Power: 16 |
Dear Philip
The idea of under-relaxing boundary conditions helped in the context of stabilization. Although, still the solution is unstable in the range of Ue greater than 10. But at least helped me to increase the boundary values of Ue up to 10. This is the snippet I am using to under-relax a fixedValue boundary condition: Code:
const scalar& relaxFactor = 0.00001; const scalarField& Ueold = Ue.boundaryField()[patchI]; Ue.boundaryField()[patchI] == (1 - relaxFactor) * Ueold + relaxFactor * 90; Code:
#include "alphaEqnSubCycle.H" // --- Pressure-velocity PIMPLE corrector loop while (pimple.loop()) { #include "UEqn.H" #include "ElectricEqn.H" #include "SourceTerm.H" // --- Pressure corrector loop while (pimple.correct()) { #include "pEqn.H" } if (pimple.turbCorr()) { turbulence->correct(); } } runTime.write(); Code:
surfaceScalarField cPlusFlux = -DeKbT*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(Ue); surfaceScalarField cMinusFlux = DeKbT*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(Ue); fvScalarMatrix cPlusEqn ( fvm::ddt(cPlus) + fvm::div(phi, cPlus) + fvc::div(cPlusFlux) - fvm::laplacian(kappa, cPlus) ); cPlusEqn.relax(); cPlusEqn.solve(); fvScalarMatrix cMinusEqn ( fvm::ddt(cMinus) + fvm::div(phi, cMinus) + fvc::div(cMinusFlux) - fvm::laplacian(kappa, cMinus) ); cMinusEqn.relax(); cMinusEqn.solve(); Code:
fvScalarMatrix UeEqn ( fvm::laplacian(eps,Ue) == -(cPlus - cMinus) * NA * elem ); UeEqn.relax(); UeEqn.solve(); |
June 6, 2017, 13:53 |
#24 |
Philip Cardiff
Rep Power: 34 |
Hi Bobi,
The block coupled method will help the convergence of the cPlus and cMinus equations; however, it seems that currently you are limited by the convergence of the Ue equation (because of the Ue boundary conditions), so I'm not sure of coupling cMinus and cPlus will have any effect. I am not familiar with the equations/physics being solved, but personally I would try find how others have solved them (do they use coupled or staggered method, or maybe they use explicit methods or solve in the frequency domain...). Depending on the strength of the coupling between the different equations, it may be beneficial to resolve the coupling between two of the equations first before solving the third e.g. loop over cPlus and cMinus until converged and then solve Ue in an outer loop. Philip |
June 6, 2017, 17:43 |
#25 |
Bobby
Rep Power: 16 |
Dear Philip
Many thanks for your reply. The idea of looping over cPlus and cMinus equations and then get to Ue equation looks interesting. However, I have a question here, maybe I am missing sth. These are my equations (all three): As you can see, i have put the header file including these equations inside pimple loop: Code:
while (pimple.loop()) { #include "UEqn.H" #include "ElectricEqn.H" #include "SourceTerm.H" // --- Pressure corrector loop while (pimple.correct()) { #include "pEqn.H" } if (pimple.turbCorr()) { turbulence->correct(); } } My Header file (ElectricEqn.H) is: Code:
surfaceScalarField cPlusFlux = -DeKbT*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(Ue); surfaceScalarField cMinusFlux = DeKbT*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(Ue); // surfaceScalarField cPlusFlux = -fvc::interpolate(sgm)*mesh.magSf()*fvc::snGrad(Ue); fvScalarMatrix cPlusEqn ( fvm::ddt(cPlus) + fvm::div(phi, cPlus) + fvc::div(cPlusFlux) - fvm::laplacian(kappa, cPlus) ); cPlusEqn.relax(); cPlusEqn.solve(); fvScalarMatrix cMinusEqn ( fvm::ddt(cMinus) + fvm::div(phi, cMinus) + fvc::div(cMinusFlux) - fvm::laplacian(kappa, cMinus) ); cMinusEqn.relax(); cMinusEqn.solve(); rhoE = (cPlus - cMinus) * NA * elem; // solve fvScalarMatrix UeEqn ( fvm::laplacian(eps,Ue) == -rhoE ); UeEqn.relax(); UeEqn.solve(); That's the point I don't get. I mean even in solving the equations once, we have satisfied the tolerance speciified in fvSolutions file through the linear matrix solver. Unfortunately, no body was interested in charge equations with super high potential values. |
June 6, 2017, 19:52 |
#26 |
Bobby
Rep Power: 16 |
Dear Philip,
This is the snippet that I can think of: Code:
const scalar& convergenceTolerance = 0.01; scalar& initialResidualA = 0.0; scalar& initialResidualB = 0.0; scalar& initialResidual = 0.0; do { surfaceScalarField cPlusFlux = -DeKbT*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(Ue); surfaceScalarField cMinusFlux = DeKbT*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(Ue); // surfaceScalarField cPlusFlux = -fvc::interpolate(sgm)*mesh.magSf()*fvc::snGrad(Ue); fvScalarMatrix cPlusEqn ( fvm::ddt(cPlus) + fvm::div(phi, cPlus) + fvc::div(cPlusFlux) - fvm::laplacian(kappa, cPlus) ); cPlus.relax(); // cPlusEqn.solve(); initialResidualA = cPlusEqn.solve().initialResidual(); fvScalarMatrix cMinusEqn ( fvm::ddt(cMinus) + fvm::div(phi, cMinus) + fvc::div(cMinusFlux) - fvm::laplacian(kappa, cMinus) ); cMinus.relax(); // cMinusEqn.solve(); initialResidualB = cMinusEqn.solve().initialResidual(); initialResidual = (initialResidualB > initialResidualA) ? initialResidualB : initialResidualA; } while (initialResidual > convergenceTolerance); |
June 6, 2017, 21:35 |
#27 |
Bobby
Rep Power: 16 |
Unfortunately, above snippet did not help.
It seems that although it gaurantees that in each time step initial residual is less than a specific value, however, after couple of iterations, it reaches to a point that can not reduce initial residual and again divergence happens. |
June 7, 2017, 00:03 |
#28 | |
Arjun
Rep Power: 34 |
How are you under relaxing the last Poisson equation. |
June 7, 2017, 00:22 |
#29 |
Bobby
Rep Power: 16 |
Hi Arjun
At first, I applied the under-relaxation to the matrix of coefficients (under-relaxing equation) as follows: Code:
fvScalarMatrix UeEqn ( fvm::laplacian(eps,Ue) == -rhoE ); UeEqn.relax(); UeEqn.solve(); Code:
fvScalarMatrix UeEqn ( fvm::laplacian(eps,Ue) == -rhoE ); Ue.relax(); UeEqn.solve(); These are the values for the fields: Code:
relaxationFactors { fields { Ue 0.01; cMinus 0.001; cPlus 0.001; } equations { } } Code:
const polyPatchList& patches = mesh.boundaryMesh(); forAll (patches,patchI){ if(patches[patchI].name()=="midup"){ const scalar& relaxFactor = 0.0001; const scalarField& Ueold = Ue.boundaryField()[patchI]; Ue.boundaryField()[patchI] == (1 - relaxFactor) * Ueold + relaxFactor * 2; } |
June 7, 2017, 01:20 |
#30 |
Arjun
Rep Power: 34 |
The reason why I asked this question is that you can not apply implicit URF to Laplacian. You can only have explicit urf. By applying implicit URF to last equation it is not really converging for you.
What you should do is to use urf = 1 for this equation. Personally I would not use coupled solver for it, I would first solve cplus and cminus (may be coupled or segregated). Then I would solve the Laplacian with explicit urf. (Not implicit). Note that the situation here is quite similar to flow solver where momentum takes implicit urf but pressure takes explicit urf (because it is Poisson). In your situation even urf = 0.95 does not work (only way is to use urf = 1).. PS (edited to add): In case of Stokes flow where momentum is also Poisson then implicit urf is not applied and there we again apply explicit urf and it is difficult to solve. |
June 7, 2017, 11:29 |
#31 |
Bobby
Rep Power: 16 |
Dear Arjun
Thanks for your comment. So, basically, what you recommend is: Code:
fvScalarMatrix UeEqn ( fvc::laplacian(eps,Ue) == -rhoE ); UeEqn.solve(); I am gonna try it and give the feedback. Regards |
June 7, 2017, 12:37 |
#32 | |
Arjun
Rep Power: 34 |
Yes, we do not apply implicit urf to Poisson part. We use explicit urf to make it stable. This is why it is better to take them out of the loop or if it is coupled then use no urf. And yes, it will be less stable with coupled (contrary to what most believe). |
June 8, 2017, 22:42 |
#33 |
Bobby
Rep Power: 16 |
Arjun,
I realized that explicit discretizing of Poisson equation in my case leads to immediate divergence. Regards |
June 9, 2017, 01:58 |
#34 | |
Arjun
Rep Power: 34 |
Let me come upto speed on this one. option (a) you are solving all three equations in one coupled system? option (b) only 2 equations are solved in coupled manner but poisson equation was solved separately after cplus and cminus were solved. So which one it is? For option (a) I expect immediate divergence. For option (b) the divergence depend on explicit under relaxation. (this you seem not to be using). PS: Is it possible for you to show me what exactly we are solving here because you are solving flow, turbulence etc. So how exactly cplus and cminus are used along with flow? Or are they part of some other model. |
June 10, 2017, 21:01 |
#35 |
Bobby
Rep Power: 16 |
Arjun,
Thanks for your reply. Here, I am interested in tracking ions in laminar fluids. Two transport equations are solved (3 unkowns incluing anions, cations and electric potential) plus a Poisson equation (the 3rd required equation). The fluid flow is laminar. I have mentioned equations in detail in this post: Snippet for redefining fixedGradient boundary condition for a patch inside solver What I am doing is : solving all above 3 equations in a loop (in segregated manner) to assure convergence in each time step: (shows more stability, however, still diverges) Code:
const scalar& convergenceTolerance = 0.01; double initialResidual = 0.0; double initialResidualA = 0.0; double initialResidualB = 0.0; double initialResidualC = 0.0; do { surfaceScalarField cPlusFlux = -DeKbT*fvc::interpolate(cPlus)*mesh.magSf()*fvc::snGrad(Ue); surfaceScalarField cMinusFlux = DeKbT*fvc::interpolate(cMinus)*mesh.magSf()*fvc::snGrad(Ue); fvScalarMatrix cPlusEqn ( fvm::ddt(cPlus) + fvm::div(phi, cPlus) + fvc::div(cPlusFlux) - fvm::laplacian(kappa, cPlus) ); initialResidualA = cPlusEqn.solve().initialResidual(); fvScalarMatrix cMinusEqn ( fvm::ddt(cMinus) + fvm::div(phi, cMinus) + fvc::div(cMinusFlux) - fvm::laplacian(kappa, cMinus) ); initialResidualB = cMinusEqn.solve().initialResidual(); initialResidual = (initialResidualB > initialResidualA) ? initialResidualB : initialResidualA; rhoE = (cPlus - cMinus) * NA * elem; // solve fvScalarMatrix UeEqn ( fvm::laplacian(eps,Ue) == -rhoE ); initialResidualC = UeEqn.solve().initialResidual(); initialResidual = (initialResidualC > initialResidual) ? initialResidualC : initialResidual; } while (initialResidual > convergenceTolerance); |
August 9, 2017, 12:49 |
#36 | |
Anthony Perri
Hey I just wanted to attach a nice thread if you want to use the refCast snippet in a newer version of OF:
of4 refCast complains |
August 9, 2017, 12:58 |
#37 | |
Tony
Rep Power: 10 |
March 30, 2018, 22:28 |
#38 |
Bobby
Rep Power: 16 |
Dear Fellows
I have a question with regard to this custom boundary conditions as attached, any hint is appreciated. |
April 1, 2018, 23:51 |
A question regarding this boundary condition
#39 |
Bobby
Rep Power: 16 |
Dear Fellows
I have written the following boundary condition: in OpenFOAM as: Code:
if(cPlus.boundaryField()[ID].type()=="fixedGradient"){ fixedGradientFvPatchScalarField& gradcPlusPatch = refCast<fixedGradientFvPatchScalarField>(cPlus.boundaryField()[ID]); scalarField& gradcPlusField = gradcPlusPatch.gradient(); gradcPlusField = -cPlus.boundaryField()[patchI]* Ue.boundaryField()[ID].snGrad()+jPlus; } My coordinate system (y) is upwards and perpendicular to the boundary patch. As shown in the attached figure. However, this boundary condition is based on normal vector (j+) and normal gradients & Now, my question is when y is upwards and also inwards; I know that OpenFOAM calculates the gradients outwards (i.e. in my figure). What happens to the normal vector (here j+) which I know that has an outwards direction. or in simple words, here in the figure y is upwards, and j+ outwards, should I put a positive value or negative value here in this boundary condition in OpenFOAM (the last line) when my boundary condition is ? Code:
gradcPlusField= -cPlus.boundaryField()[patchI]*Ue.boundaryField()[ID].snGrad()+jplus; |
April 5, 2018, 16:03 |
#40 |
Bobby
Rep Power: 16 |
Dear Fellows
I want to make a slight change to this boundary to not be applied when the value at the patch becomes negative (go back to zero gradient). Before this change, the working boundary was: Code:
const polyPatchList& patches = mesh.boundaryMesh(); forAll (patches,patchI){ if(patches[patchI].name()=="midup"){ if(cMinus.boundaryField()[patchI].type()=="fixedGradient"){ fixedGradientFvPatchScalarField& gradcMinusPatch =refCast<fixedGradientFvPatchScalarField> (cMinus.boundaryField()[patchI][i]); scalarField& gradcMinusField = gradcMinusPatch.gradient(); gradcMinusField = eKbT * cMinus.boundaryField()[patchI][i] * Ue.boundaryField()[patchI][i].snGrad()+Dinv*currentj; } } I can think of sth like this: Code:
const polyPatchList& patches = mesh.boundaryMesh(); forAll (patches,patchI){ if(patches[patchI].name()=="midup"){ forAll (patchI, facei){ if (cMinus.boundaryField()[patchI][facei] < 0) { fixedGradientFvPatchScalarField& gradcMinusPatch = refCast<fixedGradientFvPatchScalarField>(cMinus.boundaryField()[patchI][facei]); scalarField& gradcMinusField = gradcMinusPatch.gradient(); gradcMinusField = 0; } else if(cMinus.boundaryField()[patchI][facei] > 0) { if(cMinus.boundaryField()[patchI].type()=="fixedGradient"){ fixedGradientFvPatchScalarField& gradcMinusPatch = refCast<fixedGradientFvPatchScalarField>(cMinus.boundaryField()[patchI][facei]); scalarField& gradcMinusField = gradcMinusPatch.gradient(); gradcMinusField = eKbT * cMinus.boundaryField()[patchI][facei] * Ue.boundaryField()[patchI][facei].snGrad() + Dinv * currentj; //3.13e13; //midup } }} } } Code:
/home/babak/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H:110:35: error: cannot dynamic_cast ‘r’ (of type ‘double’) to type ‘class Foam::fixedGradientFvPatchField<double>&’ (source is not of class type) return dynamic_cast<To&>(r); ^/home/babak/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H:115:40: error: request for member ‘type’ in ‘r’, which is of non-class type ‘double’ << "Attempt to cast type " << r.type() ^/home/babak/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H:119:35: error: cannot dynamic_cast ‘r’ (of type ‘double’) to type ‘class Foam::fixedGradientFvPatchField<double>&’ (source is not of class type) return dynamic_cast<To&>(r); ^ Regards |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 37 | November 29, 2024 11:15 |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 13:46 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
