error when compile a new solver on version 4.1 |
February 21, 2017, 06:23 |
#21 |
And this part is your local cluster configuration problem. Or maybe problem of not careful enough reading of the cluster user guide.
Maybe someone else has desire to go through all these "and what is the contents of stderr log file?", "what log file?" "one with *.e<digits> name", "there is not such file" etc. |
February 23, 2017, 16:26 |
#22 |
Philippose Rajan
Rep Power: 25 |
Hello Bill,
A Good day to you. Have you tried running each command of the bash script you have written as individual commands from the command prompt? That way, you can debug each command to see where the error is taking place. Another option could be to try (at the command prompt): Code:
./<scriptname> &> result.log Hope this helps you a little. Regards, Philippose |
February 24, 2017, 05:58 |
#23 | |
Bill Wang
Rep Power: 12 |
Thank you for your professional reply. Problem solved. Your way saved me a lot of time.Brilliant answer!!! Have a good day. Best, Bill |
Unable to compile solver | hwsv07 | OpenFOAM Programming & Development | 10 | February 21, 2018 10:41 |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 09:05 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
bubbleFoam validation case | balkrishna | OpenFOAM Running, Solving & CFD | 24 | August 30, 2010 05:37 |
How to compile an unsteady solver based on solver of MRFSimpleFoam? | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | April 27, 2010 12:16 |
