Trouble with programming parabolic velocity BC |
January 18, 2017, 20:50 |
Outside US and Canada
Hi, everyone.
I need to program a new BC allowing to prescribe a 3D parabolic velocity profile for circular inlet of a pipe with an arbitrary orientation in space (in foam-extend 3.1). In addition, I'd like to use average flow rate rather than velocity. I started from parabolicVelocityFvPatchVectorField BC designed for prescribing parabolic profile only along one axis. Moreover, It is necessary to provide velocity and normal vector for this type of BC. I changed the code for my purpose but faced the problems (described after the code). Below is a snippet of code (part of the function updateCoeffs) that works correctly for setting the velocity in the pipe oriented along coordinate axis (parabolicProfile.png). Code:
boundBox bb(patch().patch().localPoints(), true); vector ctr = 0.5*(bb.max() + bb.min()); const vectorField& c = patch().Cf(); vectorField n = patch().nf(); //scalar maxU = 2*(avgQ_ / gSum(patch().magSf())); scalar patchRadius = mag(bb.max()-bb.min()) / (2 * sqrt(2.0)); scalarField coord = mag(c-ctr) / (patchRadius); // maxU_ is read from the "0/U" dictionary. vectorField::operator=((-1)*n*maxU_*(1.0 - sqr(coord))); 1) If I try to replace maxU_ with avgQ_ (uncomment the line and make the necessary changes in other places), I can compile the code and run calculations (using simpleFoam). But during the reconstruction of case I always get the error when reconstructing the velocity field. The error is float point exception. The question is how such code changing can lead to this error? I would be grateful for any hint. 2) When the pipe is located with an arbitrary orientation, I always get the error immediately after run the case (listing below). Code:
[13] —> FOAM FATAL ERROR: [13] gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type parabolicInletFlowVelocity) on patch rightInlet of field U in file "/home/denis/foam/denis-3.1/run/testParabolicBC/processor13/0/U" You are probably trying to solve for a field with a generic boundary condition. [13] [13] From function genericFvPatchField<Type>::gradientInternalCoeffs() const [13] in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 811. [13] FOAM parallel run exiting Thank you in advance. |
parabolic velocity |
Problem with Parabolic Velocity Profile | Allan_Carey93 | OpenFOAM Running, Solving & CFD | 4 | November 26, 2015 07:11 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
parabolic inlet velocity condition | a_cucen | Fluent UDF and Scheme Programming | 4 | March 4, 2015 10:15 |
[swak4Foam] problem with a parabolic velocity profile | Claudio87 | OpenFOAM Community Contributions | 5 | May 29, 2014 10:30 |
