Re-read basicPsiThermo from temperature file.
Old   January 7, 2017, 07:55
Default Re-read basicPsiThermo from temperature file.
Oleg Sutyrin
OlegSutyrin is on a distinguished road
I'm developing custom solver based on rhoCentralDyMFoam for foam-extend 3.2 (which is closest to OpenFOAM v3, I believe).
Initial condition, including thermodynamics, is read from 3 files: p, T, U:
autoPtr<basicPsiThermo> pThermo
    basicPsiThermo::New(mesh)
basicPsiThermo& thermo = pThermo(); //reads p and T?
volScalarField& p = thermo.p();
volScalarField& e = thermo.e();
const volScalarField& T = thermo.T();
const volScalarField& psi = thermo.psi();
const volScalarField& mu = thermo.mu();
volVectorField U //reads U
    IOobject
        "U",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    thermo.rho(),
    rhoBoundaryTypes
For some in-solver preprocessing I use mag(grad(rho)) field to locally refine mesh. Then - apply some parts of setFields.C code so that p, T, U files are overwritten using new mesh and new values. The problem is that in-solver fields are not updated. I believe that p and U may simply be updated by re-reading from files with 'p.read()' and 'U.read()'. But how to update T and rho fields? Both 'thermo.correct()' and 'thermo.read()' seem not to do anything in this context.
In the original rhoCentralFoam, thermodynamics is updated via solving density, momentum and energy equations and using thermo.correct():
(code is simplified for reading)
solve(fvm::ddt(rho) + fvc::div(phi));
solve(fvm::ddt(rhoU) + fvc::div(phiUp));
U = rhoU/rho;
solve(fvm::ddt(rhoE) + fvc::div(phiEp) - fvc::div(sigmaDotU));
e = rhoE/rho - 0.5*magSqr(U);
thermo.correct();
p = rho/psi; //psi is 1/(RT)
So, if I understand that correctly, values are updated by chain: (rho) -> (U using rho) -> (e using rho and U) -> (T using e in thermo.correct) -> (p using rho and T).
Chain i'm trying to implement would be backward: (T) -> (rho).
P.s. The whole thing is needed only to apply setFields to locally refined mesh AND preserve correct refinementHistory for further adaptive mesh refinement. The other way would be to manually preprocess the mesh with setSet and refineMesh, then apply setFields command-line utility. But refineMesh doesn't generate refinementHistory (thus all cells are considered of refineLevel 0 which ruins AMR later). Maybe there is a way to generate refinement history upon preprocessing and the load it into solver upon creating dynamicFvMesh?
OlegSutyrin is offline   Reply With Quote
Old   January 7, 2017, 17:26
Oleg Sutyrin
Found a workaround that use standalone utility that reads fields (including thermo, like original rhoCentralFoam does), refines mesh once, writes mesh (including refinement history), applies setField and exits. Running this utility several times in a row results in exactly what I need as an initial state for my custom solver: refined mesh, updated field values and refinement history.
Old   March 18, 2021, 08:03
Nicolas Cerulus
NCerulus is on a distinguished road
Hi Oleg,
I am currently trying to run rhoCentralDyMFoam with AMR using, like you mag(grad(rho)) as my criteria for refinement however it doesnt seem to work as, mag(grad(rho)) is not an available volScalarField. I've seen methods with creating new solvers etc but was wondering if you knew of an easier work around?
thanks
Nic
NCerulus is offline   Reply With Quote
Old   March 18, 2021, 08:13
Oleg Sutyrin
Hey NCerulus,
If i remember correctly, there was no easy workaround, so I had to create my custom solver. By the way, it turned out that AMR overhead computational costs were so big (in my case, at least) that using of simple fine even-sized mesh wasn't much slower that AMR mesh.
(edit) Here is, i believe, the latest code of my solver, OF4 version: https://yadi.sk/d/dlOe6YqwXfUNgA
Old   March 18, 2021, 10:20
Nicolas Cerulus
Hi Again
thank you very much for your source files that helps a lot with my issues. i am going to try and use your solver you provide to see if it has the desired outcome. I have compiled your solver however when i try and run i get an error saying that the rhoCentralGradDyMFoamCoeffs keyword is undefined, which make sense as i have not defined it in my dynamicMeshDict, Attached:
dynamicMeshDict.txt
do you have an example of your dynamicMeshDict so i can understand what needs to be included?
I have been using the following resource to build my dict:
https://openfoamwiki.net/index.php/P...nt_Definitions and it works fine for the usual rhoCentralDyMFoam with OF-6
Old   March 18, 2021, 10:29
Oleg Sutyrin
No, it seems that I haven't saved these dict files... It is possible to get the idea from the source code and reimplement these coeffs, I think.
Old   March 18, 2021, 10:41
Nicolas Cerulus
No problem,
I will make my way through the source code and see if i can understand it all and will send through the dict once i have it working as well. thanks so much for your help already!
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
