Access mesh cell refinement levels from solver.
Old   January 1, 2017, 12:41
Question Access mesh cell refinement levels from solver.
Oleg Sutyrin
OlegSutyrin is on a distinguished road
Hi!
I'm developing [slightly more] advanced AMR method for rhoCentralDyMFoam using density gradient field. I have succeeded mostly, and will post it in this forum after some additional adjustments and tests. The only major difficulty I have is that I need to access current cell refinement level for each cell. For now I've implemented a workaround - calculation from initial and current cell sizes, but it is sloppy and costly. Direct access to cell levels would be much more effective.
As far as I know, these data are obtainable from 'hexRef8' class, which is used as 'meshCutter_' in 'dynamicRefineFvMesh' class. The problem is, when I try to call mesh.meshCutter() function, compiler tells: "error: 'class Foam::dynamicFvMesh' has no member named meshCutter".
Why mesh is of 'dynamicFvMesh' type but not of 'dynamicRefineFvMesh' type?
How to properly access meshCutter from the solver?
If it is not accessible, how should I modify the code of dynamicFvMesh or hexRef8 classes to make it accessible?
OlegSutyrin is offline   Reply With Quote
Old   January 2, 2017, 08:02
Francesco Del Citto
fra76 is on a distinguished road
Dear Oleg,
I might be wrong, but the mesh refinement level is only used by octree-based meshes, like snappyHexMesh and automatic refinement algorithms you can have in solvers. For example, you can start snappyHexMesh from a mesh having only hexahedra, which are the only elements it can refine.
A general purpose solver does not have access natively to this information because it might simply not exist. Imagine a fully-tet mesh where the tetrahedra size varies smoothly from far field to the surface.
If you use snappyHexMesh, you can use the cellLevel field it writes during the meshing process. If the field is not found, then you can switch to your expensive algorithm.
Hope this helps,
Francesco
fra76 is offline   Reply With Quote
Old   January 2, 2017, 08:17
Oleg Sutyrin
Dear fra76, thanks for the reply!
Physical problems that I simulate don't have any complex surfaces, boundary layers etc. So I don't use snappyHexMesh and instead use the simplest possible mesh - parallelepipedal - which is also the most suitable for AMR.
I'n sure that information on cell level refinement levels exists somewhere, because OpenFOAM's AMR is reversible, and levels somehow can be dumped into file along with refinement history. At least, it is certainly exist (or created each time) when we call 'mesh.update()', where AMR actually takes place.
I'm hoping to find a way to access this info from solver or make it accessible by some core engine code editing, and asking here for some guidance.
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 04:59
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
