Modelling conjugate heat transfer with boussinesq assumption |
December 24, 2016, 04:48 |
Manu Chakkingal
Rep Power: 10 |
Hello
I have a new solver with structure of chtMultiregionfoam which behaves like bouyantboussinesqpimplefoam for fluid region. I ran the simulations in series and the solution converges. When I try to run it in parallel it crashes in the first step. Used OF2.4.0 Solver , test case, HOW TO RUN IT (TXT FILE) available in: https://drive.google.com/open?id=0B6...XhFaHBGT2R0LWM I tried to reduce the courant number to attain initial stability , but then the solver crashes after 2nd time step. Code:
: Test1 deltaT = 4.5530327e-107 Test2 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1061 Increased the timePrecision from 62 to 63 to distinguish between timeNames at time 2.0707573e-07 Time = 2.07075734119138104400662664383858668770699296146631240844726562e-07 Solving for fluid region air DILUPBiCG: Solving for T, Initial residual = 0.010403611, Final residual = 2.7324966e-12, No Iterations 1 max(T) [0 0 0 1 0 0 0] 300.02011 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0099236724, No Iterations 251 time step continuity errors : sum local = 5.0400286e-07, global = 1.0693134e-19 -------------------------------------------------------------------------- mpirun noticed that process rank 4 with PID 17152 on node n11-42 exited on signal 8 (Floating point exception). Could someone help to identify if its a coding issue. I am stuck for more than a month Couldnt find any suggestions in the forum helping me..
Regards Manu |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 10:51 |
Conjugate Heat Transfer between fluid and solid | Li Yang | Main CFD Forum | 8 | March 27, 2004 12:05 |
