Help with the compiling process
Old   December 18, 2016, 20:40
Smile Help with the compiling process
Luis Felipe Rojas
luisfeliperojas95 is on a distinguished road
Good Nigth
My name is Luis Felipe Rojas Avila , Colombian Environmental Engineer. Right now I am finishing my Thesis Project. That's about simulate the DBO concentration across . I have to compile the algorithm is down this message. The issue I am having is ... ¿ Can anybody help me to find the cause for this error?
Following the description of the issue is
*The DBO Equation has been developed by me building the code in C++ Language , using a global balance with VOF method.
Is presented Here
The main factors of the equation are
phi = Flux in the main Finite Element Volume
U = Velocity on the Control Volume
k = Kinetic Constant of DBO
DBO = Biological Oxygen Demand
W = External Inlet of DBO
Then I made the principal code for my problem that is presented Here
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2016 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
icoFoam
Description
Transient solver for incompressible, laminar flow of Newtonian fluids in terms of DBO balance over a geometry that contains water free flow.
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
pisoControl piso(mesh);
#include "createFields.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "CourantNo.H"
// Momentum predictor
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
if (piso.momentumPredictor())
solve(UEqn == -fvc::grad(p));
// --- PISO loop
while (piso.correct())
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, U, phiHbyA, rAU);
// Non-orthogonal pressure corrector loop
while (piso.correctNonOrthogonal())
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve(mesh.solver(p.select(piso.finalInnerIte r())));
if (piso.finalNonOrthogonalIter())
phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
// --- DBO Solver
#include "DBOeq.H"
#include "Eeq.H"
fvScalarMatrix DBOeq
(((fvm::((phi)/(U))*DBO())-((fvm::(phi)/(U)))+((((fvm::((phi))/(U))*(DBO-DBO*k)+(fvm::ddt(DBO)))))))-(W)/fvm::(U) == (((((E)/(U))*(DBO-DBO*k)+((E)/(U))*(((DBO-DBO*k)))+(((S))))))
&nbsp;);
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
Then I present the Header files (Auxiliary Files)
//Solve the DBOEquation
//Takes the DBO Value for the General Balance Equation
//Leer datos de entrada
//Calcular la ecuacion general a partir de los datos que se tienen
// (((phi)/(U))*DBO())
//-(((phi)/(U))*ddt(DBO*k)-
//+((phi)/(U))*(DBO-DBO*k)
//+((Etotal)/(U))*(DBO-DBO*k)
//-fvm::ddt(DBO)
//== fvOptions(DBO)
(((fvm::((phi)/(U))*DBO())-((fvm::(phi)/(U)))+((((fvm::((phi))/(U))*(DBO-DBO*k)+(fvm::ddt(DBO)))))))+(W)/(U) == (((((E)/(U))*(DBO-DBO*k)+((E)/(U))*(((DBO-DBO*k)))+(((S))))))
&nbsp;);
solve(DBOeq == fvOptions(DBO));
DBOeq.relax();
Then I have the Code for Eeq.H
Ep as double
Ucorr as double
En as double
Etotal as double
Dxm as double
Dx as double
S as double
//Dx == //Es el valor de Delta T para la Celda
//#include <checkMesh>
Dxm = min(magSf());
// Calcular factor de dispersion longitudinal
//#include <checkMesh.H>
//#include "fvCFD.H"
Dxm = min(magSf());
Dx = min(sqrt(magSf()));
Ep = 0.011*(((pow(U,2)*(pow(Dxm,2))/((Dx*U)));
//Calculo del factor de correccion para Ep
H = sqrt(magSf());
S = 0.50;
Ucorr = (pow(9.81*H*S,0.5));
//#include <iostream>
Ucorr = Ucorr&
E = (Ucorr*Dx)/(2);
if (En < Ep);
E = Ep-En;
else
Etotal = 0
return 0;
Having all these the compiler wmake shows me the next information
The main problem I see is
*¿ What does mean in C++ error
''make: *** [Make/linux64Gcc46DPOpt/DBOQUAL2KFOAM.o] Error 1''?
*¿Is this Related with the fact that when I try to type the name of the Solver OpenFOAM doesn't return any result like this Image.
Because I want to run it , But any reason that doesn't let me work my solver.
I will Appreciate any help with my problem. I attach the Solver folder with the log file on a txt file.
luisfeliperojas95 is offline   Reply With Quote
Old   December 19, 2016, 07:34
Agustín Villa
agustinvo is on a distinguished road
Hola Luis Felipe,
it seems your log file is cut. Could you put it completelly? Usualy, in the first line of that bunch of lines you have the explanation of your problem.
agustinvo is offline   Reply With Quote
Old   December 19, 2016, 19:04
Smile The Log File posted
Luis Felipe Rojas
Originally Posted by agustinvo View Post
Hola Luis Felipe,
Thanks for your help . Here is the Completely log file when I execute te compilation process. Thanks for your Help
bod, concentration, development, pisofoam, solver
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
[OpenFOAM.org] MPI compiling and version mismatch pki OpenFOAM Installation 7 June 15, 2015 17:21
