DynamicsMeshFv - Rotating motion with prescribed time
Old   November 30, 2016, 20:35
Default DynamicsMeshFv - Rotating motion with prescribed time
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello Guys;
Hope every one is doing great.! Right so I am trying to do this very simple mesh motion where an airfoil will Rotate ( Pitch ) in jumps at prescribed times rather than going through constant motion. I guess what I am trying to say is for example:
At time = 0 mesh is at 0 degrees.
for time = 1 mesh is at 0 degrees ( no motion until then).
At time =1.5 mesh pitchs 5 degree (just once) and then there is no rotation again until next prescribed time.
Now I don't mind using omega to integrate this jump rather than manually giving the Pitch angles or Angle of attacks in my case.
Foam::septernion
Foam::solidBodyMotionFunctions::rotatingTimeMotion::transformation() const
    scalar t = time_.value();
    scalarField YY;
    for (int i = 0; i = 5; i++)
        YY[0] = 0;
        YY[i+1] =  YY[i] + 0.01;
    Info << "YY " << YY << endl;
    if (time_.value() == YY[i])
    scalar angle  = omega_ -> integrate(0,t);
    quaternion R(axis_, angle);
    septernion TR(septernion(origin_)*R*septernion(-origin_));
    Info<< "solidBodyMotionFunctions::rotatingTimeMotion::transformation(): "
        << "Time = " << t << " transformation: " << TR << endl;
    return TR;
    else
    scalar angle  = 0;
    return TR;
In the above code I have a scalarField YY which has the prescribed times.
For example let's say prescribed times are 0.01 0.02 0.03 0.04...
So what I am really trying to achieve here is:
If actual physical time of simulation = YY[i] ( that is either 0.01 or 0.02 or 0.03 or 0.04) then make a single mesh motion.
When tested there was no mesh motion from time = 0 to time = 0.01 and it moved just once for time = 0.01. After that there was no more motion at ALL . So I thought that there is no condition for the code to walk along the YY[i] field. Therefore I included;
If ( time = YY[i])
then YY[i] = YY[i+1]
but this didnt work as well. Is there any way I can compare ( time t to any value in this YY scalarField or array] and if condition is met then exectue this kind of dynamic mesh motion.
Sorry about the lengthy ramble.
Cheers, thanks
shereez234 is offline   Reply With Quote
Old   December 6, 2016, 06:18
shereez234's Avatar
M Sereez
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2013 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "rotatingTimeMotion.H"
#include "addToRunTimeSelectionTable.H"
#include "Tuple2.H"
#include "IFstream.H"
#include "interpolateSplineXY.H"
#include "mathematicalConstants.H"
using namespace Foam::constant::mathematical;
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace solidBodyMotionFunctions
    defineTypeNameAndDebug(rotatingTimeMotion, 0);
        solidBodyMotionFunction,
        rotatingTimeMotion,
        dictionary
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::solidBodyMotionFunctions::rotatingTimeMotion::rotatingTimeMotion
    const dictionary& SBMFCoeffs,
    const Time& runTime
    solidBodyMotionFunction(SBMFCoeffs, runTime)
    read(SBMFCoeffs);
// * * * * * * * * * * * * * * * * Destructors * * * * * * * * * * * * * * * //
Foam::solidBodyMotionFunctions::rotatingTimeMotion::~rotatingTimeMotion()
Foam::septernion
for (label i = 0; i <= times_.size(); i++)
    // FIRST IF LOOP
    if ( t <= times_[0])
    vector eulerAngles = amplitude_*sin(omega_*0);
    eulerAngles *= pi/180.0;
    quaternion R(eulerAngles.x(), eulerAngles.y(), eulerAngles.z());
    return TR;
    if ( (t == times_[i]))
    vector eulerAngles = amplitude_*sin(omega_*t);
    return TR;
    if (( t > times_[i]) && t < times_[i+1])
    vector eulerAngles = amplitude_*sin(omega_*times_[i]);
    return TR;
bool Foam::solidBodyMotionFunctions::rotatingTimeMotion::read
    solidBodyMotionFunction::read(SBMFCoeffs);
    fileName newTimeDataFileName
        fileName(SBMFCoeffs_.lookup("timeDataFileName")).expand()
    if (newTimeDataFileName != timeDataFileName_)
        timeDataFileName_ = newTimeDataFileName;
        IFstream dataStream(timeDataFileName_);
    if (dataStream.good())
            List<scalar> timeValues
                dataStream
            times_.setSize(timeValues.size());
            forAll(timeValues, i)
                times_[i] = timeValues[i];
        else
            FatalErrorIn
                "solidBodyMotionFunctions::rotatingTimeMotion::read"
                "(const dictionary&)"
            )   << "Cannot open time data file " << timeDataFileName_
                << exit(FatalError);
    SBMFCoeffs_.lookup("origin") >> origin_;
    SBMFCoeffs_.lookup("amplitude") >> amplitude_;
    SBMFCoeffs_.lookup("omega") >> omega_;
    return true;
// * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
Class
Description
    SolidBodyMotionFvMesh 6DoF motion function.
    The rotation is defined by an origin and axis of rotation and an angular
    speed.
SourceFiles
    rotatingTimeMotion.C
#ifndef rotatingTimeMotion_H
#define rotatingTimeMotion_H
#include "solidBodyMotionFunction.H"
#include "primitiveFields.H"
#include "point.H"
#include "DataEntry.H"
#include "autoPtr.H"
#include "Vector2D.H"
namespace Foam
                          Class rotatingTimeMotion Declaration
class rotatingTimeMotion
    public solidBodyMotionFunction
    // Private data
        point origin_;
        //- Axis vector
        vector amplitude_;
        //- Angular velocty (rad/sec)
         scalar omega_;
        fileName timeDataFileName_;
        //- Field of times
        scalarField times_;
    // Private Member Functions
        //- Disallow copy construct
        rotatingTimeMotion(const rotatingTimeMotion&);
        //- Disallow default bitwise assignment
        void operator=(const rotatingTimeMotion&);
public:
    //- Runtime type information
    TypeName("rotatingTimeMotion");
    // Constructors
        //- Construct from components
        rotatingTimeMotion
            const Time& runTime
        //- Construct and return a clone
        virtual autoPtr<solidBodyMotionFunction> clone() const
            return autoPtr<solidBodyMotionFunction>
                new rotatingTimeMotion
                    SBMFCoeffs_,
                    time_
    //- Destructor
    virtual ~rotatingTimeMotion();
    // Member Functions
        //- Return the solid-body motion transformation septernion
        virtual septernion transformation() const;
        //- Update properties from given dictionary
        virtual bool read(const dictionary& SBMFCoeffs);
} // End namespace solidBodyMotionFunctions
} // End namespace Foam
#endif
time file:
0.01
0.02
0.03
0.04
0.05
0.06
0.07
0.08
0.09
1.00
and Dynamic Mesh dict:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    solidBodyMotionFunction  rotatingTimeMotion;
    rotatingTimeMotionCoeffs
		origin        (0.06 0 0);
       amplitude       (0 0 -10);
        omega           14000; // rad/s  (8deg/s)
		timeDataFileName "sj";
SOLVED. ( ps: in dynamic mesh i am rotating the whole mesh because it is quite coarse but you could specify cell zone)
Above are C and H files. This automates the whole process of Airfoil in an angle of attack in a prescribed time for those who are interested. It is modified from oscillating rotation motion.
It is a dirty code at the moment but does what it needs to do. So any contributions, editions are welcome.
Regards
Shereez
Old   December 6, 2016, 06:47
Wouter van der Meer
wouter is on a distinguished road
hello shereez234,
My knowledge of programming dates from the steam age but than I was learned that comparing two doubles never gives the wanted results so:
if ( a == b )
becomes
if (abs(a-b)<eps)
I think you can replace the for loop by i++ after the moment you had success with the new time so in the if block. This will remove the loop so decrease the execution time.
hope this helps
Wouter
wouter is offline   Reply With Quote
Old   December 6, 2016, 08:20
shereez234's Avatar
M Sereez
Originally Posted by wouter View Post
hello shereez234,
if ( a == b )
becomes
if (abs(a-b)<eps)
hope this helps
Wouter
That is a very good advice thanks. And actually it works even now. But with times Field (+- small) the == can be changed to < > i.e. comparison to times lower and times Upper. For example if times = 1; times_Upper can be 1+ 1e-07; and ties lower can be 1- 1e-07; I tested this method and it works too.
Thank you for the advice again.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 07:41
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
