November 19, 2016, 20:15 |
LES Time averaging Huge Oscillations
Mirage
Rep Power: 14 |
Dear OF-Users,
I am running an LES simulation and I have some questions concerning the time averaging in OpenFOAM 3.0 for a incompressible solver: pisoFoam. I start to average my field after 10 FTT (flow thought times). I observed that in the first averaged FTT huge oscillations occur, when i monitor pMean over the time in one point (attachment pMeanVsTime_point1.png ). I think that these oscillations will effect the result accuracy even after 30 FTT . Is that correct? So I took my field result after 20 FTT and deleted all the averaged variables (pMean, UMean, ...) and the field averaging properties in the uniform folder and I started to average from 20 FTT. However is this case huge oscillations occur also! (attachment pMeanVsTime_point1_Avg20.png ) As you can see the sign of pMean is changing after the new averaging... is that wrong? Are huge Amplitude effecting the quality of results? Why do they occur in the beginning of the averaging? How can i avoid this huge oscillations? here is how I do the averaging in the controlDict: Code:
functions { fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; fields ( U { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; } T { mean on; prime2Mean on; base time; } ); } |
January 27, 2017, 10:20 |
Rep Power: 10 |
I have a similar problem, however with an IDDES. If anybody could give an advice, I would be grateful
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
[solidMechanics] solidMechanics gear contact in rotation | nlc | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 11, 2015 06:41 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
