November 15, 2016, 11:38 |
Use cell values instead of vertices
Agustín Villa
Rep Power: 15 |
Hello
a long time ago, in this thread, I updated an application to do a spatial averaging in one direction. The application provides you a surface with your averaged data, but it is using vertices values, instead of cell values. I have been checking the code, but I don't know how to modify it to use the cell value (as all the surfaces you sample provides). Does anyone have an idea? The code is here Thanks! |
November 15, 2016, 16:54 |
Mahdi Hosseinali
Rep Power: 18 |
this might help:
http://www.cfd-online.com/Forums/ope...tml#post546806 |
Node or Cell Values | Diger | FLUENT | 4 | October 8, 2019 12:22 |
pointer to make one cell point to another to share values and future changes | will99 | OpenFOAM Running, Solving & CFD | 0 | July 11, 2014 01:23 |
Assigning values for outlet boundary from its adjacent cell | Ali.nabavi | Fluent UDF and Scheme Programming | 7 | July 12, 2013 16:11 |
cell values in UDF | gayatri | FLUENT | 2 | February 27, 2007 19:18 |
high difference between cell and nodal values | Trilok | FLUENT | 2 | November 13, 2003 04:38 |
