October 25, 2016, 02:56 |
obtaining NodeID's from a patch group
Stephen Waite
Rep Power: 13 |
Hi Guys,
I am looking for a way to retrieve the NodeIDs or Node numbers that are part of a patch group, so I can apply node specific boundary conditions. I've had a look through some of the source files relating to patches and boundary fields but I haven't seen anything yet. I'm not actually sure if this information is stored in OpenFOAM once the mesh files are read in. I could probably also work with faceIDs if that is an option, there is a member function whichFace in polyPatch.C that I will have a play with, but If anyone has already done something similar that would help speed things up. Any help would be great. Cheers Stephen |
faces, nodes, patch field |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Are my IRIXbs systune parametersb setting correct | lakeat | OpenFOAM Installation | 1 | May 5, 2008 10:48 |
