October 13, 2016, 05:57 |
OpenFOAM zero Equation Turbulence Model
Hello Every one;
I have been trying to code the zero equation turbulence model Baldwin - Lomax inorder to replicate some results from a published journal paper. I have been able to remove the k and omega PDE's from a 2 equation turbulence model in order to begin this with. It works on a principle of calculating two different turbulent viscosity. One for Outer region (Hence nut_Outer) and one for Inner region ( nut_Inner). The two viscosity regions are separated at a wall distance value where the nut_Inner and nut_Outer are equal. nut_Inner is calculated using prandit's van driest formulation and nut_Outer is calculated using a function for wake region and Intermittency factor (Fwake and Fkleb). The whole model in theory can be found on CFD online wiki: http://www.cfd-online.com/Wiki/Baldwin-Lomax_model All the coding went well until I had to define yCrossOver: Code:
Foam::dimensioned<double> BL::yCrossOver(const volScalarField& NDiff, const volScalarField& nut_Inner) const { Foam::dimensioned<double> arg = min(y_); if (NDiff < ((nut_Inner/nut_Inner)*1e-7)) { return arg; } else { return false; } } Now the question is how I do get the minimum value of y ( walldistance) when nut_Inner is equal to nut_Outer? How do I code this bit? Sorry about the lengthy post and have a good day! Thank you. Shereez |
October 13, 2016, 11:07 |
#2 | ||
Joachim Herb
Rep Power: 22 |
and https://github.com/OpenFOAM/OpenFOAM...kLOmega.H#L203 Here the wall distance is calculated using the OpenFOAM class wallDist. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Turbulent frequency equation for compressible kOmegaSST turbulence model | Bojan | OpenFOAM Programming & Development | 1 | September 6, 2013 07:45 |
OpenFOAM: LES turbulence model names | Ollie | OpenFOAM | 5 | January 7, 2013 11:24 |
k-e turbulence model and energy equation | Blob | Main CFD Forum | 0 | May 29, 2009 09:35 |
