LES in OF 3.0.1, no Output for nuSgs
Old   October 4, 2016, 14:38
Default LES in OF 3.0.1, no Output for nuSgs
Mirage
Mirage is on a distinguished road
Dear Foamers,
I am running a LES Simulation in OF 3.0.1 and unfortunately I am not getting any output file for nuSgs.
The declaration of LES and turbulence model in OF 3.0.1 was changed comparing with older version. I declared my LES properties in the turbulenceProperties as following:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType  LES;
LES
LESModel        Smagorinsky;
turbulence      on;
printCoeffs     on;
delta           vanDriest;
printCoeffs     on;
SmagorinskyCoeffs
    ce 1.048;
    ck 0.047147; //Cs = 0.1
vanDriestCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
    Aplus           26;
    Cdelta          0.158;
Here is the nuSgs file in 0 folder:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      nuSgs;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet_cyclic
        type            cyclic;
    outlet_cyclic
        type            cyclic;
    heatedWall
        type            zeroGradient;
    topWall
        type            zeroGradient;
     back1a
        type            cyclic;
     front1a
        type            cyclic;
     back1b
        type            cyclic;
     front1b
        type            cyclic;
     back1c
        type            cyclic;
     front1c
        type            cyclic;
     back2a
        type            cyclic;
     front2a
        type            cyclic;
     back2b
         type            cyclic;
     front2b
        type            cyclic;
     back2c
        type            cyclic;
     front2c
        type            cyclic;
     back3a
        type            cyclic;
     front3a
        type            cyclic;
     back3b
        type            cyclic;
     front3b
        type            cyclic;
     back3c
         type            cyclic;
     front3c
        type            cyclic;
     back3d
        type            cyclic;
     front3d
        type            cyclic;
     back3e
        type            cyclic;
     front3e
        type            cyclic;
     back4
        type            cyclic;
     front4
        type            cyclic;
I was wondering, why i do not have any nuSgs file and if this could effect my result quality.
Do you think, that the LES declaration is correct?
How can I fix the problem?
Thank you in advance for your help
Mirage is offline   Reply With Quote
Old   October 4, 2016, 19:00
Marco Atzori
Atzori is on a distinguished road
Hi!
I guess in OpenFOAM 3.0 nu_sgs has been substituted by nut.
Please check by yourself: I had a look at the initial conditions in the tutorial:
https://github.com/OpenFOAM/OpenFOAM...otorBike/0.org
And I tried to compare the Smagorinsky model in the different versions:
https://github.com/OpenFOAM/OpenFOAM.../Smagorinsky.C
Cheers!!
Marco
Atzori is offline   Reply With Quote
LES help pksri ANSYS 2 April 20, 2016 01:55
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 06:05
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 17:58
