Modify the fvMatrix.
Old   September 22, 2016, 16:47
Default Modify the fvMatrix.
Haixuan Ye
yehaixuan is on a distinguished road
Hi all,
I am trying to add some off-diagonal value to a fvMatrix instance, say, setting a[i][j] = 2 (which is zero before). And i , j are the row and col, respectively.
So what I am not sure about is how many things I need to play around with? Is it enough to modify only lower() ( or upper() ), lowerAddr() and upperAddr()?
A further question is if I need to frequently insert values to the list or field above. What is the computational efficient way to do that?
Btw, I don't need to worry about the boundaryCoeffs and internalCoeffs.
Thanks in advance.
yehaixuan is offline   Reply With Quote
Old   April 11, 2019, 16:10
charles4allme is on a distinguished road
Hey,
Did you figure out the answer to your problem.
charles4allme is offline   Reply With Quote
Old   April 13, 2019, 08:51
Thang
thang_cegroup is on a distinguished road
Do you find the answer ? If yes , Could u explain to me ?
I need to modify the matrix coefficient with cyclic boundary which is not implemented for blockmatrix in foam ext-4.0 . But I do not know how to deal with it .
thang_cegroup is offline   Reply With Quote
fvmatrix
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
the openfoam source term and fvmatrix problem wenxu OpenFOAM Programming & Development 0 September 5, 2014 11:56
modify fvMatrix / coupled equations / higher order diffusion Jinming OpenFOAM Programming & Development 0 May 7, 2011 07:20
