Incompressible Euler Equations with SIMPLE method
Old   September 22, 2016, 05:36
Default Incompressible Euler Equations with SIMPLE method
Fujiang Yu
yfjok22 is on a distinguished road
Hello, Foamers
I'm now working on a test case which will refer to the solving of Euler Equations. During several days' work, I got one question
I'm planning to SIMPLE method to solve a 3D steady incompressible Euler Equation, so I just changed a bit on UEqn of the official simpleFoam, like this
MRF.correctBoundaryVelocity(U);
tmp<fvVectorMatrix> tUEqn
fvm::div(phi, U)
+ MRF.DDt(U)
//+ turbulence->divDevReff(U)
fvOptions(U)
fvVectorMatrix& UEqn = tUEqn.ref();
UEqn.relax();
fvOptions.constrain(UEqn);
if (simple.momentumPredictor())
solve(UEqn == -fvc::grad(p));
fvOptions.correct(U);
Acutally, just wiped out the turbulence term on the momentum equation
However, when I try to test this new solver, simpleEulerFoam, on the offical case, pitzDaily, it comes a error
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon|omega|f|v2)" tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
No MRF models present
No finite volume options present
Starting time loop
streamLine streamlines:
automatic track length specified through number of sub cycles : 5
Time = 0.001
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
Even decrease the time interval, it doesn't change. So, guys, do you get any idea on this reslut
It should be the reason that I modify simpleFoam to a Euler Equation solver in a wrong way, or it's because Euler Equation can't be solved by SIMPLE method, or some artificial viscosity would be needed.
Please give some idea and suggestion
thx^^
yfjok22 is offline   Reply With Quote
Old   September 22, 2016, 09:11
A_Pete is on a distinguished road
I am not sure, about the origin of your error, but I know that the form of the coefficient matrix changes if you modify an equation. It is possible that your symGaussSeidel solver is not suited for your knew equation. Maybe try another solver, but it is just a guess, since I found this behaviour when changing transport equations.
A_Pete is offline   Reply With Quote
euler equations, incompressible problem, simple algorithm
Combining compressible incompressible equations in cht Taukiki OpenFOAM Programming & Development 0 December 23, 2015 13:35
well-posedness of incompressible Navier-Stokes equations tas38 Main CFD Forum 1 September 11, 2015 16:41
compressible SIMPLE method fakor Main CFD Forum 1 August 30, 2010 12:21
How to calculate drag/lift forces, using SIMPLE method. abcdef123 Main CFD Forum 4 December 7, 2009 14:16
Euler equations? Jan Ramboer Main CFD Forum 2 August 19, 1999 02:58
