Error about missing file pointZones when using submesh
Old   September 20, 2016, 22:16
Default Error about missing file pointZones when using submesh
Thomas Oliveira
t.oliveira is on a distinguished road
Dear all,
From a Foam::fvMesh object and a Foam::labelHashSet object, I create a submesh:
Foam::fvMeshSubset subsetter(mesh);
subsetter.setLargeCellSubset(voidCells);
Foam::fvMesh& subMesh = subsetter.subMesh();
From this submesh, I create a Foam::fvMesh object:
Foam::fvMesh mesh
    Foam::IOobject
        Foam::fvMesh::defaultRegion,
        runTime.timeName(),
        runTime,
        Foam::IOobject::MUST_READ
    Xfer < pointField > (subMesh.points()),
    Xfer < faceList >   (subMesh.faces()),
    Xfer < labelList >  (subMesh.faceOwner()),
    Xfer < labelList >  (subMesh.faceNeighbour())
When I run, I receive the error
cannot find file /home/user/solver/case/constant/polyMesh/pointZones at line 0.
However, if replace it by
Foam::fvMesh mesh
    Foam::IOobject
        runTime.timeName(),
        runTime,
I receive no error. Can you please help me identify the problem?
Best wishes,
Thomas
t.oliveira is offline   Reply With Quote
Old   September 20, 2016, 22:20
Thomas Oliveira
Dear Thomas,
When you use
Foam::fvMesh mesh
    Foam::IOobject
        runTime.timeName(),
        runTime,
you call Foam::fvMesh::fvMesh(const IOobject& io), which calls Foam::polyMesh::polyMesh(const IOobject& io), which initialises pointZones_ using the read option Foam::IOobject::READ_IF_PRESENT.
When you use
Foam::fvMesh mesh
    Foam::IOobject
        runTime.timeName(),
        runTime,
you call Foam::fvMesh::fvMesh(const IOobject& io, const Xfer<pointField>& points, const Xfer<faceList>& faces, const Xfer<labelList>& allOwner, const Xfer<labelList>& allNeighbour, const bool syncPar), which calls Foam::polyMesh::polyMesh(const IOobject& io, const Xfer<pointField>& points, const Xfer<faceList>& faces, const Xfer<labelList>& owner, const Xfer<labelList>& neighbour, const bool syncPar), which initialises pointZones_ using the read option io.readOpt(), which is Foam::IOobject::MUST_READ in your case.
That is why you get the error if the file pointZones doesn't exist just in this second case. You may want to use this instead:
Foam::fvMesh mesh
    Foam::IOobject
        runTime.timeName(),
        runTime,
so that io.readOpt() will be Foam::IOobject::READ_IF_PRESENT.
Best wishes,
Thomas
file missing, fvmesh, ioobject, mesh
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
