Implementing new viscosity model
Old   September 6, 2016, 01:18
Default Implementing new viscosity model
Viraj Belekar
viraj20feb is on a distinguished road
Greetings,
I am trying to implement a new viscosity model for a non-newtonian fluid in foam extend 3.1. I follow the steps mentioned here: http://www.tfd.chalmers.se/~hani/kur...nts/Report.pdf
When I try to give this command: cp -r --parents \ src/transportModels/incompressible/viscosityModels/BirdCarreau/ \ $WM_PROJECT_USER_DIR
the output is: cp: with --parents, the destination must be a directory
Try 'cp --help' for more information.
Can someone help me in this endeavour?
Thanks
viraj20feb is offline   Reply With Quote
Old   September 6, 2016, 07:07
T.D. is on a distinguished road
Simply do:
cp -r $WM_PROJECT_DIR/src/transportModels/incompressible/viscosityModels/BirdCarreau $WM_PROJECT_USER_DIR
Regards,
T.D.
T.D. is offline   Reply With Quote
Old   September 7, 2016, 02:11
Smile
Viraj Belekar
Thank you so much Mr. T.D
Viscosity model - error: object is not allocated - C++ beginner avila.vc OpenFOAM Programming & Development 5 February 14, 2022 03:00
Fluid turns into solid at given T (via viscosity UDF or solidifcation model?) jpina FLUENT 1 April 3, 2016 04:48
Viscosity model in the twoPhaseEulerFoam enoch OpenFOAM Programming & Development 3 March 17, 2016 10:53
Implementing new viscosity model prjohnston OpenFOAM Running, Solving & CFD 6 July 3, 2015 05:26
Viscosity ratio in gamma-theta transition model based on k-w sst turb model Qiaol618 Main CFD Forum 8 June 9, 2012 07:43
