Create new functionObject library
Old   August 18, 2016, 13:57
Default Create new functionObject library
Jack
Jack001 is on a distinguished road
Hi All,
I am looking to create my own function object that can be used to calculate some metrics during runtime by including my new function object in $FOAM_CASE/system/controlDict.
According to this page http://foam.sourceforge.net/docs/cpp/a00004.html this should be easy and so I need to implement "libMyFunctionObjectlib.so" in the same way that there is already an implementation for "libForces.so". Then I imagine I can modify an existing .so file and do what I need there, compile the new library and I'm done. The only problem is I can't seem to find these .so files!
I have tried searching using grep -r "libForces.so" $FOAM_SRC but I get nothing!
Any ideas?
Jack001 is offline   Reply With Quote
Old   August 24, 2016, 15:16
Mahdi Hosseinali
anishtain4 is on a distinguished road
You don't modify .so objects!!! you modify the source code and compile it to make your own .so object, then put the lib("libMyFunctionObject.so"); to your controlDict and that makes your possible to use your function object there.
Also it would be helpful to take a look at this thread:
http://www.cfd-online.com/Forums/ope...on-object.html
anishtain4 is offline   Reply With Quote
Old   August 24, 2016, 15:17
Mahdi Hosseinali
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 10:55
using a Fortran library of thermodynamics inside sutherland transport model Mehdi3031 OpenFOAM Programming & Development 0 April 7, 2016 10:34
Troubles when create a new volScalarField in my own library mxylondon OpenFOAM Programming & Development 6 June 20, 2013 03:42
How to create my own functionObject ? panda60 OpenFOAM 5 May 25, 2010 10:39
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
