source term modification in poisson equation does not affect results
Like Tree7Likes
Old   August 17, 2016, 18:58
Default source term modification in poisson equation does not affect results
Bobby
babakflame is on a distinguished road
Dear Fellows
I have written a simple poissonFoam code which contains a source term in form of a sinh function.
The code solves this equation:
\nabla^2  \varphi = \beta sinh (\alpha \varphi).
I have attached the code and a sample case. I have assigned different values for \alpha and \beta, however, I get the following distribution every time. Do u have any idea why this happens and how would I be able to see the effect of \alpha and \beta on the results?
PS: in the attached picture, phi is nondimensionalized by the value at the left boundary of sample case (alpha3.tar.gz) and x is non-dimensionalized by 30e-09.
babakflame is offline   Reply With Quote
Old   August 18, 2016, 00:13
Bobby
Dear Fellows
I have posted the text of my poissonFoam.c and createFields.H files below. Probably, I have a problem in clearly defining my source term:
poissonFoam.C :
#include "fvCFD.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    Info<< "\nStarting iteration loop\n" << endl;
    while (runTime.loop())
        Info<< "Iteration = " << runTime.timeName() << nl << endl;
        solve
            fvm::laplacian(phi) - beta*sinh(alpha*phi)
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
createFields.H :
   Info<< "Reading physicalProperties\n" << endl;
    IOdictionary physicalProperties
        IOobject
            "physicalProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    dimensionedScalar alpha
        physicalProperties.lookup("alpha")
    dimensionedScalar beta
        physicalProperties.lookup("beta")
    Info<< "Reading field phi\n" << endl;
    volScalarField phi
        IOobject
            "phi",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
Any hint is kindly appreciated.
Old   August 19, 2016, 23:22
Bobby
Dear Fellows
I figured out my problem. It was on the value of Phi which actually made the hyperbolic function be in the location near zero.
BTW: the poisson solver works perfectly. feel free to use it.
Tobi likes this.
Old   August 22, 2016, 10:19
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Yes, phi is in radian
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   September 5, 2016, 22:18
Bobby
Dear Fellows
I am experiencing a weird issue in dealing with poisson equation in OpenFoam. In the first post of this thread you can see that I have written a poissonFoam code that works with openFoam 2.1.x.
This code solves the following relation:
Actually, I am interested in solving above equation in one dimensional which in my grid would be from left wall to right wall.
My issue is with the grids. If I use a rectangular shaped grid with known and fixed values for \varphi on left and right boundaries, the result is a linear distribution for
\varphi. The linear distribution mathematically happens merely when the source term in poisson equation is zero (in my case \beta sinh (\alpha \varphi)). But my source term is not zero.
However, if the grid be a sector with the angle of 1^\circ, then the resulting distribution for
\varphi is an exponential distribution.
I have attached the grid types with the achieved distribution for
\varphi.
As you can see from the figures the value of \varphi at left wall is 25.4e-03 and on the right wall is 0.
Actually, I am interested in solving the above poisson equation in 1 dimensional. So, using a sector (even with 1 degree) is somehow unphysical for me.
Has some body else experienced sth similar to me? or any hint on this weird experience?
Is there any way to solve above equation on rectangular-shaped grid?
You have my solver above, you can try this by yourself and see what happens.
Old   September 6, 2016, 04:27
Tobi's Avatar
Tobias Holzmann
Hello Bobi,
I am not 100% sure but if we would solve the simple laplace equation for a disc (or wedge) we would observe the same result. The analytical solution for the temperature equation within a cylinder is a logarithmic law (not linear). So I think everything is okay with your calculation.
Keep foaming,
Tobias Holzmann
Old   September 6, 2016, 14:13
Bobby
Hey Tobi
Many thanks for your reply. Let me explain this a little further.
I am interested in solving equation
\nabla^2  \varphi^ {\ast}= \beta sinh (\alpha \varphi \ast) in 1 dimensional situation with non-zero value at left side and zero value at right hand side. In one dimensional I have:
\frac{d^2 \varphi^ \ast}{d \eta ^2}= \beta sinh (\alpha \varphi \ast)
Here
\eta = \frac {y}{h} is the non-dimensional coordinate and \varphi^ \ast = \frac{\varphi}{\zeta} is the non-dimensional variable present in poisson equation.
Here, \zeta is the value of the left wall used to non-dimesionalize the
\varphi variable.
Since the right boundary is zero, by integrating twice, the above non-dimesional equation gives the following solution:
\varphi ^ \ast = \frac{4}{\alpha} tanh^{-1} \left[tanh (\frac {\alpha}{4}) exp (-\sqrt{\alpha \beta}\eta)\right]
In the attached picture, you can observe the analytic solution:
I am interested in solving above equation with
\alpha =1 , \beta = 10000, h=30e-09 , \zeta= 25.4e-03.
AFA I know, first of all, I need to make this equation dimensioanl in 1D and solve it with my solver. How ever, as I described in previous post, the results are based on grid shape which is weird for me. I mean If I use rectangular grid, result is linear and with curved left and right walls, result are exponential, however, I want the above solution seen in my results without grid shape dependancy
Am I missing sth here?
By the way, the dimensional equation which I am solving becomes as follows:
\frac{d^2 (\varphi / \zeta)}{d (y / h)^2}= \beta sinh (\alpha \varphi / \zeta)
That is so weird for me
Old   September 9, 2016, 15:14
Bobby
Dear Fellows
The last thing that comes to my mind is that "probably there is a bug in O.F.2.1.x since It can not solve the Poisson equation (which is actually a Laplacian equation with source term) correctly on rectangle grids.
My equation is \nabla^2  \varphi^ {\ast}= \beta sinh (\alpha \varphi \ast)
with left boundary condition 1 and right boundary condition zero would give the following exponential solution:
However OF. 2.1.x gives linear disribution on roughly 1D rectangle grids
Old   September 11, 2016, 05:13
Tobi's Avatar
Tobias Holzmann
What came into mind is, what is alpha in your graph? Degrees? If yes, you have to transform this into Radian because foam work's with radian.
Keep foaming,
Tobias Holzmann
Old   September 11, 2016, 15:11
Bobby
Dear Tobi
Many thanks for your reply and your time.
Here, \alpha is just a coefficient that helps us to achieve different exponential distributions. Otherwise, all results are the same.
As it is seen in the attached figure, the following distributions are achieved by assuming different values for \alpha from 1 to 10 and \beta is just another constant considered to be equal to 10000.
I just want to solve the following Poisson equation in 1 dimensional. This direction is assumed to be y direction between two boundaries. The value at left boundary is considered to be \zeta (could be any value) and right boundary is zero.
The non-dimensional equation is:
\frac{d^2 \varphi^ \ast}{d \eta ^2}= \beta sinh (\alpha \varphi^ \ast)
using these scales: \eta = \frac {y}{h}  \quad, \varphi^ \ast = \frac{\varphi}{\zeta}
I found the dimensional equation as:
which finally becomes:
\frac{d^2 (\varphi )}{d (y^2)}= \frac{\beta \zeta}{h^2} sinh (\frac{\alpha}{\zeta} \varphi)
Here, I have used the value of h= 3e-06 and \beta=1000 ,\quad  \zeta= 25.4e-03 and \alpha from 1 to 10.
I have uploaded my results from the above curved grid. However, a roughly 1 D rectangular grid just gives linear lines. Even , my results from a curved grid are not fitted completely.
Here, in my results, the distance from the wall has been divided by 30e-09.
PS: the distance between left and right boundary is considered to be 120e-09 m in my simulation. So \chi is from 0 to 4.
Old   September 12, 2016, 05:49
Tobi's Avatar
Tobias Holzmann
Dear Bobi,
I am sorry for the last replay. I did not read everything and I saw that I already mentioned the stuff with the radian. Well I am not so familiar with non-dimensionalizing equations and using them in OpenFOAM. If the solution (integral) is correct, you should be able to get the same or closely the same values.
  • In my opinion you will always have differences between the wedge and linear mesh. For me it is simply because of the fact that if we would solve only the laplace equation, we would also observe different behaviors. Wedge - curved (the analytical solution is a logarithmic one); 1D mesh, linear solution. This is related to the non linear distribution from the inner ring to the outer ring. Like, inner ring: area = x; outer ring: area = y while x << y.
  • I checked your source term:
\mathrm{sinh}{(\phi \alpha)}
To do that, I made a new field and stored it. The result of the source term is as expected (like the distribution you showed). The behavior is like a 1/x function but based on the small grid, the source term become like 1e-8 which will not decrease your quantity phi very much and that is the reason for the linear distribution. By the way, I was implementing the following equation:
\frac{\partial \phi}{\partial t} - \frac{\partial^2 \phi}{\partial x^2} = \beta \mathrm{sinh}{(\phi \alpha)}
Maybe the fact that I did not non-dimens. this equation lead to the behavior I got. In any case I have to say that I never did something like you are doing at the moment and therefore I am sorry not to provide you more information. Maybe Sergei (Zappo) or other more advanced and skilled people can help you in that topic.
Good luck Bobi.
babakflame likes this.
Keep foaming,
Tobias Holzmann
Old   September 12, 2016, 11:04
Bobby
Thanks Tobi.
I will try to add transient term and check it that way too.
Old   September 16, 2016, 14:00
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
But your plots "numeric/analytical" are qualitatively very similar. Unfortunatelly, I don't know why they don't match completely.
Zeppo is offline   Reply With Quote
Old   September 16, 2016, 16:18
Bobby
@Tobi
many thanks for your time Tobi. Actually, I made an elliptic code (without time derivative) that now applies the Poisson equation with sinh source term on rectangular grids correctly. But still a problem exists.
@Sergei
Thanks Sergei for looking at my question.
Actually, I made a code that solves
\frac{d^2 \varphi}{d x ^2}= \beta sinh (\varphi) on rectangular grids
Right Now, I am capable of achieving results up to the value of \beta = 9 and the results seem fine. However, further increasing of \beta will result in the following error:
0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  __sinh_finite in "/lib/x86_64-linux-gnu/libm.so.6"
#4  sinh in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::sinh(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
 at ??:?
 at ??:?
 at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Floating point exception (core dumped)
The code is so simple, that other than refining grid and reducing the PCG solver tolerance into lower than 10e-11 nothing comes to my mind. The following parts show the createFields and poisson.C routines:
 volScalarField beta
        IOobject
            "beta",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
    dimensionedScalar("beta", dimensionSet(0, -2, 0, 0, 0, 0, 0), scalar(12.0))
    volScalarField phi
        IOobject
            "phi",
            runTime.timeName(),
            mesh,
        mesh
    volScalarField tmp1
        IOobject
            "tmp1",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
         // Foam::sinh(alpha * phi)
        1 *  Foam::sinh(phi)
        solve
              fvm::laplacian(phi) -  beta * sinh(phi)
//          fvm::laplacian(phi) - beta * (phi + (1/6)*pow(phi,3) + (1/120)*pow(phi,5) + (1/362880)*pow(phi,9) + (1/39916800)*pow(phi,11))
        runTime.write();
            << nl << endl;
I even tried to implement the sinh term as a summation of polynomials, but this did not remove the above error.
The following is my fvSolution and fvSchemes:
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(phi)  Gauss linear corrected;
 phi
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-11;
        relTol          0.0;
If you could help me figure out this error, I would really appreciate it.
Old   September 16, 2016, 16:40
Zeppo's Avatar
Sergei
Does the error show up before even iteration process starts running?
Old   September 16, 2016, 16:47
Bobby
Hi Sergei
Actually, it pops up after around 100 iterations, I monitored the value of \varphi, it seems that by increasing the vaue of \beta over 9, during the simulation the \varphi value exceeds 1e22 and leads into the above error.
However, this deosn't happen for lower values of \beta
Old   September 16, 2016, 17:22
Tobi's Avatar
Tobias Holzmann
based on the fact that you do not have a time derivation (this is somehow a limiter), you should underrelax your equation. For that you have to build the matrix first, relax it and then solve it. I am not sure if it will help but I think it should. If you increase the value of the quantity beta, your problem gets more stiff and your solution procedure has to be improved. That is my experience but I think Sergei can make a better statement.
Good luck.
Keep foaming,
Tobias Holzmann
Old   September 16, 2016, 17:27
Bobby
Thanks Tobi
Your suggestion makes sense to me too.
I will try it and provide the feedback.
Regards
Old   September 16, 2016, 17:55
Bobby
Hey Tobi,
I built the matrix and did the relaxation as follows inside poisson.C file as:
fvScalarMatrix phiEqn
         phiEqn.relax();
         phiEqn.solve();
I think these were the required modifications. Is there anything else that I forgot?
Now, the code runs for \beta =9, however, for \beta = 12 gives the same error:
Iteration = 0.0005
DICPCG:  Solving for phi, Initial residual = 1, Final residual = 7.04378610773e-12, No Iterations 79
ExecutionTime = 0.07 s  ClockTime = 1 s
Iteration = 0.00055
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
 at ??:?
 at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
I will test the code with time derivative as well and produce the feedback.
Regards
Old   September 16, 2016, 17:57
Tobi's Avatar
Tobias Holzmann
I am not sure if my assumptions were correct. It was just a guess. Well, do you have the necessary entries in the fvSolutions? I think so, or not?
relaxationFactors
    equations
         phi       0.3;
         phiFinal   1;
Keep foaming,
Tobias Holzmann
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
implicit - scalar product source term in momentum equation vinch OpenFOAM Running, Solving & CFD 0 October 28, 2014 15:57
UDF for source term in momentum equation Enrico FLUENT 9 May 30, 2014 12:34
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
