incompressibleTwoPhaseInteractingMixture implementation
Old   August 10, 2016, 21:01
Default incompressibleTwoPhaseInteractingMixture implementation
Desanga
desanga is on a distinguished road
Hi Foamers,
I have a question to ask you. This isn't directly related to CFD but its about C++ implementation of incompressibleTwoPhaseInteractingMixture.H (applications/solvers/multiphase/driftFluxFoam/incompressibleTwoPhaseInteractingMixture/).
As you can see inside incompressibleTwoPhaseInteractingMixture.H, this is a derived class from three base classes ( public IOdictionary,public transportModel,
public twoPhaseMixture). The constructor of this class is implemented as below ( incompressibleTwoPhaseInteractingMixture.C).
Foam::incompressibleTwoPhaseInteractingMixture::
const volVectorField& U,
const surfaceScalarField& phi
IOdictionary
IOobject
"transportProperties",
U.time().constant(),
U.db(),
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
twoPhaseMixture(U.mesh(), *this),
it only invokes the constructors of IOdictionary, twoPhaseMixture. As long as I know, we should call all the base class constructors inside the constructor of the derived class. There is no sign of transportModel class constructor (transportModel.H does not have any default constructors). This is the original code inside driftfluxFoam and it compiles without any errors.I think, I have missed something here. Do you guys have some explanation to matter?
Thanks in advance
desanga is offline   Reply With Quote
Old   August 12, 2016, 13:14
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
a) you do not give any information about which foam version you are using (http://www.cfd-online.com/Forums/ope...tml#post613817)
b) the next time it would be better to use code tags
c) In the latest release (Foundation 4.x) the class you mentioned inherits everything from these classes:
class incompressibleTwoPhaseInteractingMixture
    public compressibleTransportModel,
and the constructor call that you miss for the compressibleTransportModel is:
    // Constructors
        //- Construct from components
It does not take any argument and hence you do not need to call it. Hence, the world is fine
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
c++, openfoam
Free CFD code with implementation of Menter's k-omega SST model nikola_m Main CFD Forum 2 May 8, 2020 13:13
Issues in FGM combustion model implementation Lisandro Maders OpenFOAM Programming & Development 15 April 22, 2020 20:18
a little confused with the implementation of compressibleInterFoam su_junwei OpenFOAM Running, Solving & CFD 2 May 7, 2014 18:33
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 06:10
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 08:29
