Add solar radiation to laplacianFoam
Old   August 5, 2016, 11:50
Default Add solar radiation to laplacianFoam
aaron outhwaite
aar_out is on a distinguished road
Hi all,
I am working on a (relatively) simple problem involving a slab thermal mass - here water - and the heat equation:
ρC_p*∂T/∂t=-∇∙(k∇T)+(q_v )
In this case, the source term q_v is a solar load that is incident on a single patch (1 5 4 0), resulting in a change in the slab temperature.
I would like to use laplacianFoam for this (to start), and then move to more complicated buoyant and multi-region solvers. I have played around with adding q_v as a source term to the laplacianFoam.c file, but with the coding required to properly track the diurnal variations in the solar load, I prefer instead to add solar radiation using the solarLoad solver (as part of the radiationModel package available in v1606+).
As such, I need to add radiationModel.H to the laplacianFoam solver. This is where I get lost; I've tried to copy the radiationModel.H implementation in more complex solvers, but get lost in the details.
Has anyone else tried to add radiation to laplacianFoam? Any help would be greatly appreciated!
aar_out is offline   Reply With Quote
Old   August 5, 2016, 12:09
aaron outhwaite
Attached image is the scenario that I am considering.
Last edited by aar_out; August 5, 2016 at 12:10. Reason: (via Ismail + Henriquez 2003)
Old   April 30, 2017, 16:12
Sergio López Sánchez
sergiolopezsan is on a distinguished road
I am also doing something like that. Did you get the solution to the problem?
sergiolopezsan is offline   Reply With Quote
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Floating point error with Solar radiation Ruzic STAR-CCM+ 1 December 21, 2012 15:38
solar radiation javad814 OpenFOAM 0 September 27, 2011 14:16
solar radiation javad814 OpenFOAM 0 September 23, 2011 17:43
Solar radiation though double glazing Multiband CFX 0 January 26, 2009 09:19
