kinematic cloud properties-Regd
Old   July 12, 2016, 07:21
Default kinematic cloud properties-Regd
thegauravonline's Avatar
GS
thegauravonline is on a distinguished road
Dear All,
I would like to understand what is the meaning of "rhoMin" & "rho0" in the kinematic Cloud properties file in Lagrangian solver of foam-extend3.2
I want to specify and vary the density of the particles that I inject. For this, where should I make changes.
Please let me know if you are aware of this...
Also, please let me know these: "minParticleMass" & "RosinRammlerPDF"
Thank you.
thegauravonline is offline   Reply With Quote
Old   July 14, 2016, 04:44
Karelke Yu
cfdopenfoam is on a distinguished road
Hi, Gaurav.
Has your problem solved? Could you please post your answers here so that more foamers can benifit from you?
Best,
cfdopenfoam is offline   Reply With Quote
Old   July 14, 2016, 05:10
Ping Chang
chpjz0391 is on a distinguished road
Originally Posted by thegauravonline View Post
Dear All,
Thank you.
Hi Gaurav,
You may find the answer for how to inject vary density particles from this post.
http://www.cfd-online.com/Forums/ope...aticcloud.html
rhoMin means minimum density (kg/m3) I think it's for parcel.
rho0 means particle density kg/m3 (constant) for single particle
minParcelMass means minimum parcel mass kg
And one parcel could include many particles.
the parameter nParticle means the number of particles for each parcel. If you set it as 1. It will be DEM.
Kind regards,
Ping
chpjz0391 is offline   Reply With Quote
Old   July 14, 2016, 08:22
GS
Originally Posted by chpjz0391 View Post
Hi Gaurav,
Kind regards,
Ping
Dear Ping,
Thank you for the reply.
But, I do not want to inject particles of varying densities, at one time, in the flow.
I would like to inject particles of uniform density once, later in the next set of simulations, I want to inject particles with different value of density but uniform for all the particles.
In this regard, I want to understand the difference between 'rho' and 'rho0' mentioned in the kinematicCloudProperties file.
Thanks
Old   July 14, 2016, 08:25
GS
Originally Posted by cfdopenfoam View Post
Hi, Gaurav.
Best,
I haven't yet fully understood that.
Once, I come to know, I will let it to be known.
Thank you
Old   July 14, 2016, 21:40
Ping Chang
Dear Ping,
Thanks
Hi Gaurav,
Which solver are you using? DPMFoam? I have checked the kinematicCloudProperties file in DPMFoam tutorial, I did not find the parameter rho. There are only rhoMin and rho0 and I have explained that in my last post.
Old   July 15, 2016, 00:56
GS
Hi Peng,
I am using icoLagrangianFoam in the Lagrangian solver. There also it is mentioned rhoMin and rho0 only. I have mistakenly queried for rho.
But, Is there a limit on the value of rho0. Because, if i am changing the default value(5000) to some less values, foam is giving errors(FLOATING POINT EXCEPTION). Also, for moderate values of rho0, the solution is running only upto a limited number of time steps than that is mentioned in the controlDict file.
Could you please clarify this. Thank you.
Old   July 15, 2016, 00:59
Ping Chang
Hi Peng,
Hi Gaurav,
Could you post your error information (for more details) and kinematicCloudProperites file as well? And I recommend you to use a latest version.
Regards.
Ping
Old   July 15, 2016, 01:45
GS
Hi Ping,
The error messages are:
With "rho0-500 and rhoMin-150"
Time = 1.051
Courant Number mean: 0.156148 max: 535.037 velocity magnitude: 115.568
Evolving kinematicCloud
--> Cloud: kinematicCloud
Added 5 new parcels
Total number of parcels added = 5255
Total mass introduced = 2.80267e-05
Current number of parcels = 4254
Current mass in system = 2.2688e-05
DILUPBiCG: Solving for Ux, Initial residual = 0.990552, Final residual = 2.55921e-06, No Iterations 32
DILUPBiCG: Solving for Uy, Initial residual = 0.919057, Final residual = 5.83568e-06, No Iterations 32
DILUPBiCG: Solving for Uz, Initial residual = 0.938345, Final residual = 7.10839e-06, No Iterations 32
DICPCG: Solving for p, Initial residual = 0.682208, Final residual = 9.11394e-07, No Iterations 114
time step continuity errors : sum local = 3.32876e-07, global = 3.1143e-10, cumulative = -1.93215e-08
DICPCG: Solving for p, Initial residual = 0.978959, Final residual = 9.99862e-07, No Iterations 106
time step continuity errors : sum local = 1.0204e-05, global = 1.89962e-07, cumulative = 1.7064e-07
ExecutionTime = 159.17 s ClockTime = 159 s
Time = 1.052
Courant Number mean: 6.44676 max: 28233.3 velocity magnitude: 6098.39
Added 5 new parcels
Floating point exception
With "rho0-150 and rhoMin-1.0e-15"
Time = 0.002
Courant Number mean: 0.0249048 max: 5.03595 velocity magnitude: 1.42542
Added 5 new parcels
Total number of parcels added = 10
Total mass introduced = 5.33333e-08
Current number of parcels = 10
Current mass in system = 5.33333e-08
DILUPBiCG: Solving for Ux, Initial residual = 0.310019, Final residual = 9.42003e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0.356904, Final residual = 9.69334e-06, No Iterations 7
DILUPBiCG: Solving for Uz, Initial residual = 0.492843, Final residual = 3.53762e-06, No Iterations 9
DICPCG: Solving for p, Initial residual = 0.0327284, Final residual = 9.13131e-07, No Iterations 109
time step continuity errors : sum local = 8.23451e-08, global = 6.57272e-10, cumulative = 1.46996e-09
DICPCG: Solving for p, Initial residual = 0.136092, Final residual = 8.68997e-07, No Iterations 114
time step continuity errors : sum local = 8.66451e-09, global = 2.07729e-11, cumulative = 1.49073e-09
ExecutionTime = 0.47 s ClockTime = 1 s
Time = 0.003
Courant Number mean: 0.0259055 max: 5.00462 velocity magnitude: 2.06054
Added 5 new parcels
Total number of parcels added = 15
Total mass introduced = 8e-08
Current number of parcels = 13
Current mass in system = 6.93333e-08
The kinematic cloud properties file (foam-extend 3.2) is the following:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.2 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object kinematicCloud1Properties;
active yes;
// Particle sub-models
InjectionModel ConeInjection;
DragModel SphereDrag;
DispersionModel none;
PatchInteractionModel StandardWallInteraction;
PostProcessingModel PatchPostProcessing;
// Parcel basis type
parcelBasisType mass;
constantProperties{
rhoMin rhoMin [ 1 -3 0 0 0 ] 1e-15;
// Minimum particle mass
minParticleMass minParticleMass [ 1 0 0 0 0] 1.0e-15;
// Parcel thermo properties
rho0 rho0 [ 1 -3 0 0 0] 5000;
// Coupling between particles and carrier phase via source terms
coupled true;
cellValueSourceCorrection on;
// Integer used to identify different parcel types
parcelTypeId 2;
interpolationSchemes
rho cell;
U cellPointFace;
mu cell;
integrationSchemes
U Euler;
particleForces
gravity off;
virtualMass off;
pressureGradient off;
ConeInjectionCoeffs
// type patchInjection;
// patchName in;
SOI 0;
duration 7.5;
position (0 0.0024 0.0024);
direction (1 0 0);
parcelsPerSecond 5000;
volumeFlowRate constant 0.01;
Umag constant 5.0;
thetaInner constant 0.0;
thetaOuter constant 90.0;
parcelPDF
pdfType RosinRammler;
RosinRammlerPDF
minValue 50.0e-06;
maxValue 100.0e-06;
d (75.0e-06);
n (0.5);
// Total mass to inject
massTotal massTotal [ 1 0 0 0 0] 2.0e-4;
StandardWallInteractionCoeffs
type rebound;
PatchPostProcessingCoeffs
maxStoredParcels 10000;
patches (
in
out1
out2
Thank you
Old   July 15, 2016, 04:31
Ping Chang
Hi Ping,
Time = 1.051
Added 5 new parcels
Time = 1.052
Added 5 new parcels
Time = 0.002
Added 5 new parcels
Time = 0.003
Added 5 new parcels
FoamFile
version 2.0;
format ascii;
class dictionary;
active yes;
constantProperties{
coupled true;
parcelTypeId 2;
rho cell;
U cellPointFace;
mu cell;
integrationSchemes
U Euler;
particleForces
gravity off;
virtualMass off;
ConeInjectionCoeffs
// patchName in;
SOI 0;
duration 7.5;
direction (1 0 0);
Umag constant 5.0;
parcelPDF
RosinRammlerPDF
minValue 50.0e-06;
maxValue 100.0e-06;
d (75.0e-06);
n (0.5);
type rebound;
patches (
in
out1
out2
Thank you
I found two questions. The first one is that your max Co number is larger than 1.Your first case is more than 500. So you should check your controlDic file, deltaT. Did you just change the particle parameter in kinematic and did not change any other BC ? Second, the error message is "floating point exception", which means an illegal mathematical operation (like division by zero) occurred during your simulation. I recommend you to check your initial boundary condition and particle properties.
Besides, the solver you use is different with mine, I am using the OF version from www.openfoam.org. But I think this is not the reason for your problem.
Good luck
Old   July 18, 2016, 01:36
vidyadhar
vidyadhar is on a distinguished road
Thank you Ping.
Regards,
Vidyadhar/thegauravonline (from new CFD Online account)
vidyadhar is offline   Reply With Quote
Old   August 8, 2023, 06:52
Default answer
  #12
desimuser1
Desimuser1 is on a distinguished road
rho0 = your value (rho at time zero)
rhoMin = if varied, what is the least value that it has to maintain
Desimuser1 is offline   Reply With Quote
kinematic cloud properties-Regd thegauravonline OpenFOAM Programming & Development 0 July 12, 2016 07:15
kinematic cloud properties-Regd thegauravonline OpenFOAM Running, Solving & CFD 0 July 12, 2016 03:37
Conceptual misunderstanding of Kinematic Cloud class dradenkovic OpenFOAM Running, Solving & CFD 0 May 31, 2016 06:26
Kinematic cloud properies the meainig of the terms manuc OpenFOAM Programming & Development 0 February 23, 2016 08:29
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
