OpenFOAM - Control and Editing of Lagrangian Output Variables
Old   July 6, 2016, 12:42
Default OpenFOAM - Control and Editing of Lagrangian Output Variables
Gina M.
gmag is on a distinguished road
Hi everyone,
I am relatively new to OpenFOAM so I hope you'll have some patience with me! I am using OpenFOAM v3.0.0.
I am interested in adding additional Lagrangian output variables for post-processing in Paraview. After some searching, I think I have concluded that these output variables can be specified in SprayParcelIO.C. The source of my confusion is that while I see some standard parcel output variables (d0, injector, etc), I do not see quantities like temperature or droplet size...
Question #1: Where is the appropriate location to edit/control Lagrangian output variables? If it is SprayParcelIO.C, where is the parcel diameter (d) outputted?
Question #2: If SprayParcelIO.C is the correct file to edit, do I need to add the name of my custom output variable in each section where I see other parcel variable names (like "user_", "d0_",etc) or only certain sections?
Question #3: After editing the appropriate file, how should I compile the code to include these edits?
Thanks in advance for your help!
gmag is offline   Reply With Quote
Old   June 25, 2019, 13:29
hzw
hzw is on a distinguished road
Originally Posted by gmag View Post
Hi everyone,
Dear, have you found any solution to your questions? I am also interested.
hzw is offline   Reply With Quote
openfoam, post-processing., sprayfoam
