Immediate Segmentation fault when running new solver
Like Tree1Likes
Old   July 27, 2016, 05:26
Default Problem Solved
  #21
Heliana Cardenas
heliana60 is on a distinguished road
Hi Tobi! Hi guys,
I could solve my foam-extend compiling problem
if you guys have problems with flex you might want to read this:
http://www.tfd.chalmers.se/~hani/kur...sAndTricks.htm
I did somehow something similar before, but at the beginning I was not including the flex-2.5.35 libraries in all the Make/options files that were complaining about it (which were so many). So following the instructions written in the mentioned website worked for me, I modified all the Make/options, and also uncommented in ThirdParty/Allmake.stage1 this line:
# flex
( rpm_make -p flex-2.5.35 -s flex-2.5.35.spec -u http://downloads.sourceforge.net/pro...-2.5.35.tar.gz )
Cheers,
heliana
heliana60 is offline   Reply With Quote
Old   July 27, 2016, 06:16
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Good to know and sorry for the late replay.
There is also a thread about that problem but I am not going to search for it now
The problem is that the latest versions of FOAM using the newer FLEX packages that is normally not supported by old Linux distributions. So even you use an old FLEX or compile the new yourself. But it is somewhere here on cfd-online (thanks to bruno).
I also get that problem with 4.x and my ubuntu 12.04.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
foam extend
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
segmentation fault - parallel running CrisMoreira OpenFOAM Running, Solving & CFD 13 November 1, 2015 17:13
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Strange Segmentation Fault jd210 OpenFOAM Running, Solving & CFD 0 March 30, 2015 08:04
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
