adding collision to ThermoParcel
Old   June 29, 2016, 05:43
Default adding collision to ThermoParcel
Amir
amirhoshangm is on a distinguished road
I would like to add collision between particles in ThermoParcel. So I have added another layer on KinematicParcel
    typedef ThermoParcel
        ThermoParcel
             CollidingParcel
                 KinematicParcel
                      particle
    > basicThermoParcel;
and another layer on KinematicCloud.
    typedef ThermoCloud
        CollidingCloud
        KinematicCloud
            Cloud
                basicThermoParcel
    > basicThermoCloud;
I have also added following line in the makeBasicThermoParcelSubmodels.C
 makeParcelCollisionModels(basicThermoCloud);
When I compile it I will get following linking error
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O0 -fdefault-inline -ggdb3 -DFULLDEBUG -DNoRepository -ftemplate-depth-100 -I../reactingParcelFoam -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/finiteVolume/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/meshTools/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/sampling/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/TurbulenceModels/compressible/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/basic/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/intermediate/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/spray/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/distributionModels/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/transportModels/compressible/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/basic/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/reactionThermo/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/SLGThermo/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/chemistryModel/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/thermophysicalModels/radiation/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/ODE/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/regionModels/regionModel/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/regionModels/surfaceFilmModels/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/fvOptions/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/combustionModels/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/coalCombustion/lnInclude -IlnInclude -I. -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/applications/solvers/lagrangian/sprayFoam/sprayFoam.o -L/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/lib \
	    -lturbulenceModels -lcompressibleTurbulenceModels -llagrangian -llagrangianIntermediate -llagrangianTurbulence -llagrangianSpray -lspecie -lcompressibleTransportModels -lfluidThermophysicalModels -lliquidProperties -lliquidMixtureProperties -lsolidProperties -lsolidMixtureProperties -lthermophysicalFunctions -lreactionThermophysicalModels -lSLGThermo -lchemistryModel -lradiationModels -lODE -lregionModels -lsurfaceFilmModels -lcombustionModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lcoalCombustion -lOpenFOAM -ldl  \
	    -ggdb3 -DFULLDEBUG -lm -o /home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/bin/sprayFoam
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/applications/solvers/lagrangian/sprayFoam/sprayFoam.o: In function `void Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::calcSurfaceValues<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::TrackingData<Foam::SprayCloud<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::TrackingData<Foam::SprayCloud<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > > > >&, int, double, double&, double&, double&, double&, double&) const':
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/intermediate/lnInclude/ThermoParcel.C:125: undefined reference to `Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::debug'
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/applications/solvers/lagrangian/sprayFoam/sprayFoam.o: In function `void Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::setCellValues<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::TrackingData<Foam::SprayCloud<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::TrackingData<Foam::SprayCloud<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > > > >&, double, int)':
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/intermediate/lnInclude/ThermoParcel.C:52: undefined reference to `Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::debug'
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/applications/solvers/lagrangian/sprayFoam/sprayFoam.o: In function `Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::type() const':
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/src/lagrangian/intermediate/lnInclude/ThermoParcel.H:274: undefined reference to `Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> >::typeName'
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/lib/liblagrangianIntermediate.so: undefined reference to `Foam::WallModel<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ThermoParcel<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::dictionaryConstructorTablePtr_'
/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/lib/liblagrangianIntermediate.so: undefined reference to `Foam::PairModel<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ThermoParcel<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::dictionaryConstructorTablePtr_'
collect2: error: ld returned 1 exit status
make: *** [/home/amir/OpenFOAM/OpenFOAM-3.0.1/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Debug/bin/sprayFoam] Error 1
Does any body have any idea what is the problem?
amirhoshangm is offline   Reply With Quote
Old   June 29, 2016, 05:56
Andreas Weber
a.weber is on a distinguished road
You could just take the SprayParcel, which has it all combined.
a.weber is offline   Reply With Quote
Old   June 29, 2016, 06:12
Amir
thank you Andreas,
But spray parcel does not have collidingParcel
Old   June 29, 2016, 07:31
Andreas Weber
sorry my fault.
I thought about the stochasticCollision stuff.
Old   January 14, 2018, 11:41
Xiaoshuai Yuan
kk2017 is on a distinguished road
        ThermoParcel
             CollidingParcel
                 KinematicParcel
                      particle
    > basicThermoParcel;
    typedef ThermoCloud
        CollidingCloud
        KinematicCloud
            Cloud
                basicThermoParcel
    > basicThermoCloud;
Have you find a solution for this problem?
It seems that the error related to ThermoParcel could be eliminated by adding the following codes to the defineBasicThermoParcel.C file
typedef Foam::ThermoParcel<CollidingParcel<KinematicParcel <particle> > > thermoParcel;
defineTemplateTypeNameAndDebug(thermoParcel, 0);
However, the WallModel and PairModel errors still exists. Does any one know the solution?
kk2017 is offline   Reply With Quote
Old   January 14, 2018, 16:02
Rodrigo
guin is on a distinguished road
I suggest you to change the ordering, from "Thermo<Colliding<Kinematic<...>>>" to "Colliding<Thermo<Kinematic<...>>>"
guin is offline   Reply With Quote
Old   January 15, 2018, 04:34
Xiaoshuai Yuan
Thanks for the suggestion. I find a solution in this thread Colliding Coal Cloud in coalCollidingChemistryFoam, and the trick is using the code
typedef basicThermoCloud::collidingCloudType collidingParcelType;
makeParcelCollisionModels(collidingParcelType);
instead of
Old   February 5, 2021, 10:09
UOCFD
uosilos is on a distinguished road
instead of
Has that trick solved the problem??
uosilos is offline   Reply With Quote
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
chtMultiRegionSimpleFoam 3D problem Lucie OpenFOAM Pre-Processing 2 June 21, 2016 06:23
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
droplet collision in KIVA, stretching collision and reflexive collision. Mori-Nik Main CFD Forum 0 March 15, 2011 12:07
Adding collision to icoLagrangian foam alan_fergus OpenFOAM Running, Solving & CFD 0 December 12, 2006 08:55
