How to compile a new drag force in Lagrangian model
Old   May 31, 2016, 09:05
Question How to compile a new drag force in Lagrangian model
Li Linmin
lilinmin is on a distinguished road
Dear Foamers,
I am now working with the gas-particle simulation. I have added a new drag model in the Drag file as the same way as other drag forces. But a don't know how to compile it. Can anyone help me ?
Thank you very much in advance.
Linmin
lilinmin is offline   Reply With Quote
Old   May 31, 2016, 09:56
Lennart
elmo555 is on a distinguished road
Hey,
can you be a bit more specific? Which solver are you using, and how did you add the new drag model?
elmo555 is offline   Reply With Quote
Old   May 31, 2016, 10:40
Li Linmin
Originally Posted by elmo555 View Post
Hey,
Thank you very much for reply and I am sorry for that. I copied a file of the existed drag model in the file "src/lagrangian/intermediate/submodels/Kinematic/ParticleForces/Drag" and changed the code. Can it been compiled?
Old   May 31, 2016, 11:07
Lennart
Well, you need to re-compile the solver you're using, and you shouldn't modify the original OF solver. There are many tutorials out there explaining how to create a new solver based on an exisiting one, e.g. here.
Basically: copy the original code to your working folder, adjust the name and EXE path, and add your drag model (using #include) where all the other drag models are included. Then compile the solver and you should be able to use your drag model.
Old   June 9, 2016, 05:15
Andreas Weber
a.weber is on a distinguished road
BTW: The force model list is found in intermediate/parcels/include/MakeParcelForces.C
This is where you have to add it.
regards
Andreas
a.weber is offline   Reply With Quote
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
FLUENT: how to record drag force at every time step? qiulan FLUENT 4 March 20, 2017 22:22
Compute drag force on a mesh (complete beginner!) matteo.monti Main CFD Forum 0 October 10, 2014 21:07
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Please help a newbie find the drag on a 3d model David Amer Main CFD Forum 1 March 6, 2002 04:33
