Parcel position: where it is updated? (OpenFOAM 3.x)
Like Tree14Likes
Old   November 28, 2016, 16:29
Chris Cloney
DustExplosion is on a distinguished road
I haven't figured it out yet, but I made some more progress.
When I print to info in calcVelocity:
template<class ParcelType>
template<class TrackData>
const Foam::vector Foam::KinematicParcel<ParcelType>::calcVelocity
    TrackData& td,
    const scalar dt,
    const label cellI,
    const scalar Re,
    const scalar mu,
    const scalar mass,
    const vector& Su,
    vector& dUTrans,
    scalar& Spu
) const
    typedef typename TrackData::cloudType cloudType;
    typedef typename cloudType::parcelType parcelType;
    typedef typename cloudType::forceType forceType;
    const forceType& forces = td.cloud().forces();
    // Momentum source due to particle forces
    const parcelType& p = static_cast<const parcelType&>(*this);
    const forceSuSp Fcp = forces.calcCoupled(p, dt, mass, Re, mu);
    const forceSuSp Fncp = forces.calcNonCoupled(p, dt, mass, Re, mu);
    const forceSuSp Feff = Fcp + Fncp;
    const scalar massEff = forces.massEff(p, mass);
    Info<< "Fcp = " << Fcp << endl;
    Info<< "Fncp = " << Fncp  << endl;
    Info<< "massEff = " << massEff << endl;
    // New particle velocity
    // Update velocity - treat as 3-D
    const vector abp = (Feff.Sp()*Uc_ + (Feff.Su() + Su))/massEff;
    const scalar bp = Feff.Sp()/massEff;
    Spu = dt*Feff.Sp();
    IntegrationScheme<vector>::integrationResult Ures =
        td.cloud().UIntegrator().integrate(U_, dt, abp, bp);
    vector Unew = Ures.value();
    // note: Feff.Sp() and Fc.Sp() must be the same
    dUTrans += dt*(Feff.Sp()*(Ures.average() - Uc_) - Fcp.Su());
    // Apply correction to velocity and dUTrans for reduced-D cases
    const polyMesh& mesh = td.cloud().pMesh();
    meshTools::constrainDirection(mesh, mesh.solutionD(), Unew);
    meshTools::constrainDirection(mesh, mesh.solutionD(), dUTrans);
    return Unew;
I get this output on the first timestep:
Solving 1-D cloud limestoneCloud1
Fcp = ((0 0 0) 1.953585e-09)
Fncp = ((0 0 0) 0)
massEff = 1.308996939e-12
Fcp = ((0 0 0) 1.953266393e-09)
Fncp = ((0 0 0) 0)
Fcp = ((0 0 0) 1.952948152e-09)
Fncp = ((0 0 0) 0)
Fcp = ((0 0 0) 1.952630597e-09)
Fncp = ((0 0 0) 0)
The mass is the same as my analytical solution, but I get Fd = 1.03904611725e-09 for my force.
My analytical equation in ptython is
if Re > 1000:
        Cd = 0.424
    else:
        Cd = 24*(1.0 + (1.0/6.0)*pow(Re,2.0/3.0))
dV = Vinf-V
Fd = 0.5*Cd*rhof*dV*dV*Ac
Fnet = Fd
A = Fnet/mp
V = V + 0.5*(A+Aold)*dt
compared to OF which is:
template<class CloudType>
Foam::forceSuSp Foam::SphereDragForce<CloudType>::calcCoupled
    const typename CloudType::parcelType& p,
    const scalar dt,
    const scalar mass,
    const scalar Re,
    const scalar muc
) const
    forceSuSp value(vector::zero, 0.0);
    value.Sp() = mass*0.75*muc*CdRe(Re)/(p.rho()*sqr(p.d()));
    return value;
Foam::scalar Foam::SphereDragForce<CloudType>::CdRe(const scalar Re) const
    if (Re > 1000.0)
        return 0.424*Re;
    else
        return 24.0*(1.0 + 1.0/6.0*pow(Re, 2.0/3.0));
I have not been able to translate between the two yet. Does anyone see anything right away?
Also, can anyone explain how the integrator works? I tried looking before but could not figure it out. Why are both abp and bp passed into it? This seems common across a lot of lagrange models.
DustExplosion is offline   Reply With Quote
Old   November 29, 2016, 11:07
Chris Cloney
Ok, I figured some more things out although I am stuck at a basic part.
The integrator has two models, an analytic one and Euler implicit one. I will reference the analytic one for now which solves the equation
val = \alpha + (\phi - \alpha)e^{-\beta \Delta t}
template<class Type>
typename Foam::IntegrationScheme<Type>::integrationResult
Foam::Analytical<Type>::integrate
    const Type& phi,
    const scalar dt,
    const Type& alphaBeta,
    const scalar beta
) const
    typename IntegrationScheme<Type>::integrationResult retValue;
    const scalar expTerm = exp(min(50, -beta*dt));
    if (beta > ROOTVSMALL)
        const Type alpha = alphaBeta/beta;
        retValue.average() = alpha + (phi - alpha)*(1 - expTerm)/(beta*dt);
        retValue.value() =  alpha + (phi - alpha)*expTerm;
    else
        retValue.average() = phi;
        retValue.value() =  phi;
    return retValue;
In calcVelocity the values that are passed in are (assuming no noncoupled forces)
\alpha\beta = \frac{S_{p}V_{cell}}{m_{p}}
\beta = \frac{S_{p}}{m_{p}}
\alpha = V_{cell}
Therefore, the integrator solves:
V_{p, new} = V_{cell} + (V_{p} - V_{cell})e^{-\frac{S_{p}}{m_{p}} \Delta t}
So \beta is the relaxation timescale between the fluid and particle velocity. Using the sphereDrag this value is then:
\beta = t_{0} = \frac{3}{4}\frac{\mu_{cell}CdRe}{\rho_{p}d^{2}}
I have two questions that I cannot figure out from here.
One, why isn't the integrator solving the following equation? It seems like this makes more sense than the other version.
V_{p, new} = V_{p} + (V_{cell} - V_{p})e^{-\frac{S_{p}}{m_{p}} \Delta t}
and two, how is the relaxation timescale relation derived?
I know I have done it before, but I cannot seem to figure it out. I found that fluent is solving the same equation (https://www.sharcnet.ca/Software/Flu...ug/node809.htm) but I do not understand why it includes CdRe/24. Shouldn't it just be Cd? I know it has something to do with stokes law, but cannot figure it out yet. Does anyone have a hint or reference?
Thanks!
Old   December 1, 2016, 10:12
Timo Niemi
tniemi is on a distinguished road
The integrator solves
because it is the "analytic" solution of the particle velocity (assuming V_cell and Sp are constant during the time step, not true unless dt is small). As a thought experiment, consider two border cases:
1. dt = 0 -> no update to velocity
2. dt = infinity -> particle should approach cell velocity
In case 1. the exp term is 1, giving
V_{p, new} = V_{cell} + (V_{p} - V_{cell})=V_{p}
ie. the particle velocity stays the same. In case 2. the exp term goes to zero giving
V_{p, new} = V_{cell} + (V_{p} - V_{cell})0=V_{cell}
ie. the particle velocity is the cell velocity.
With
the results would not be logical. Hope this helps.
tniemi is offline   Reply With Quote
Old   December 1, 2016, 13:16
Chris Cloney
Thanks Tniemi, that makes sense. I was thinking about it the wrong way.
I am still looking for a good reference on how the relaxation timescale is derived. I thought I remembered seeing it in the "Fundamentals of Multiphase Flow" textbook but could not find it in there.
BTW, I figured out why my analytical solution from before was wrong. In addition to using the relaxation timescale equation instead of Fd = 0.5*rhof*A*dV^2, my Reynolds number calculation was wrong. It needs to be based on slip velocity not particle velocity. The updated plot looks like this
I am not sure why the particle skips around a bit reaching the maximum. The particles have coupled = false. The fluid velocity does fluctuate a bit, but only in the forth decimal place (e.g., 0.99917-1.0003) so I am not sure why the particle velocity is affected so much. Thoughts?
Old   December 2, 2016, 15:19
Chris Cloney
I have moved on to multiphase laminar flame simulations for the time being and have ran into a problem with the trackToFace function in kinematicParcel::move(). I instrumented the function with print statements. The code and example output are shown in the next two windows.
bool Foam::KinematicParcel<ParcelType>::move
    TrackData& td,
    const scalar trackTime
    typename TrackData::cloudType::parcelType& p =
        static_cast<typename TrackData::cloudType::parcelType&>(*this);
    Info << "Starting particle move function" << endl;
    td.switchProcessor = false;
    td.keepParticle = true;
    const polyBoundaryMesh& pbMesh = mesh.boundaryMesh();
    const scalarField& cellLengthScale = td.cloud().cellLengthScale();
    const scalar maxCo = td.cloud().solution().maxCo();
    scalar tEnd = (1.0 - p.stepFraction())*trackTime;
    scalar dtMax = trackTime;
    if (td.cloud().solution().transient())
        dtMax *= maxCo;
    bool tracking = true;
    label nTrackingStalled = 0;
    Info << " dtMax: " << dtMax << endl;
    Info << " End Time: " << tEnd << endl;
    Info << "Starting particle move loop" << endl;
    int loopIndex = 0;
    while (td.keepParticle && !td.switchProcessor && tEnd > ROOTVSMALL)
    loopIndex++;
    Info << " Loop index: " << loopIndex << endl;
    Info << "  End time: " << tEnd << endl;
    Info << "  Number stalled: " << nTrackingStalled << endl;
    Info << "  Position before correction: " << p.position() << endl;
        // Apply correction to position for reduced-D cases
        meshTools::constrainToMeshCentre(mesh, p.position());
    Info << "  Position after correction: " << p.position() << endl;
        const point start(p.position());
    Info << "  Starting move Calculation: " << endl;
        // Set the Lagrangian time-step
        scalar dt = min(dtMax, tEnd);
    Info << "   dt: " << dt << endl;
        // Cache the parcel current cell as this will change if a face is hit
        const label cellI = p.cell();
        const scalar magU = mag(U_);
    Info << "   Velocity Vec: " << U_ << endl;
    Info << "   Velocity Mag: " << magU << endl;
        if (p.active() && tracking && (magU > ROOTVSMALL))
            const scalar d = dt*magU;
        Info << "   Distance d: " << d << endl;
            const scalar dCorr = min(d, maxCo*cellLengthScale[cellI]);
        Info << "   Distance dCorr: " << dCorr << endl;
        Info << "   Original position: " << p.position() << endl;
        Info << "   Hypothetical position: " << p.position() + dCorr*U_/magU << endl;
        dt *=
                dCorr/d
               *p.trackToFace(p.position() + dCorr*U_/magU, td);
        Info << "   Final position: " << p.position() << endl;
        Info << "   dt_adjusted: " << dt << endl;
        tEnd -= dt;
        scalar newStepFraction = 1.0 - tEnd/trackTime;
        if (tracking)
            if
                mag(p.stepFraction() - newStepFraction)
              < particle::minStepFractionTol
                nTrackingStalled++;
                if (nTrackingStalled > maxTrackAttempts)
                    tracking = false;
            else
        p.stepFraction() = newStepFraction;
        bool calcParcel = true;
        if (!tracking && td.cloud().solution().steadyState())
            calcParcel = false;
        // Avoid problems with extremely small timesteps
        if ((dt > ROOTVSMALL) && calcParcel)
            // Update cell based properties
            p.setCellValues(td, dt, cellI);
            if (td.cloud().solution().cellValueSourceCorrection())
        Info << "  Perform momentum and thermal calculation: " << endl;
                p.cellValueSourceCorrection(td, dt, cellI);
            p.calc(td, dt, cellI);
        if (p.onBoundary() && td.keepParticle)
            if (isA<processorPolyPatch>(pbMesh[p.patch(p.face())]))
                td.switchProcessor = true;
        p.age() += dt;
        td.cloud().functions().postMove(p, cellI, dt, start, td.keepParticle);
    return td.keepParticle;
 dtMax: 1.5e-06
 End Time: 5e-06
 Loop index: 1
  End time: 5e-06
  Number stalled: 0
  Position before correction: (0.007449940411 0.0001178373267 0.0001178373267)
  Position after correction: (0.007449940411 0.0001178373267 0.0001178373267)
   dt: 1.5e-06
   Velocity Vec: (-1.63496736 0 0)
   Velocity Mag: 1.63496736
   Distance d: 2.45245104e-06
   Distance dCorr: 2.45245104e-06
   Original position: (0.007449940411 0.0001178373267 0.0001178373267)
   Hypothetical position: (0.00744748796 0.0001178373267 0.0001178373267)
   Final position: (0.007449940349 0.0001178370321 0.0001178376213)
   dt_adjusted: 0
 Loop index: 2
  End time: 5e-06
  Number stalled: 1
  Position before correction: (0.007449940349 0.0001178370321 0.0001178376213)
  Position after correction: (0.007449940349 0.0001178373267 0.0001178373267)
   dt: 1.5e-06
   Original position: (0.007449940349 0.0001178373267 0.0001178373267)
   Hypothetical position: (0.007447487898 0.0001178373267 0.0001178373267)
   Final position: (0.007449940287 0.0001178376213 0.0001178370321)
   dt_adjusted: 0
 Loop index: 3
  End time: 5e-06
  Number stalled: 2
  Position before correction: (0.007449940287 0.0001178376213 0.0001178370321)
  Position after correction: (0.007449940287 0.0001178373267 0.0001178373267)
   dt: 1.5e-06
 Loop index: 4
  End time: 3.5e-06
  Number stalled: 2
  Position before correction: (0.007449940287 0.0001178373267 0.0001178373267)
   dt: 1.5e-06
   Velocity Vec: (-1.635266068 0 0)
   Velocity Mag: 1.635266068
 Loop index: 5
  End time: 2e-06
  Number stalled: 2
   dt: 1.5e-06
   Velocity Vec: (-1.635562618 0 0)
   Velocity Mag: 1.635562618
 Loop index: 6
  End time: 5e-07
  Number stalled: 2
   dt: 5e-07
   Velocity Vec: (-1.635857025 0 0)
   Velocity Mag: 1.635857025
From the first iteration, trackToFace seems to not move the particle at all although it should be moved 2.45245104e-06. It also then triggers the particle as "stalled". I tried to look into the trackToFace function but I cannot figure out why it is stalling. Is anyone familiar with this functionality and can provide some thoughts?
My mesh is 1D with 5e-5 m cells. The other cell dimension is 2.36e-4 by 2.36e-4 (needed so my multiphase concentration works out correctly). The parcel itself is near the middle of the domain, away from any walls. As you can see the timesteps and displacements are quite small, so I am not sure what the problem is. I started looking at trackToFace but it looks complicated. Is there anyway I can just bypass it (I have outflow boundaries and am not looking to do parallel for the time being).
Thanks!
Old   December 5, 2016, 16:06
Chris Cloney
I found a fix to my trackToFace problem in the following thread: Documentation of trackToFace subroutine
The routine needs a normalization step to work properly on very high resolution meshes (micrometric). The thread also gives the original reference for the routine if anyone needs it.
Old   December 11, 2017, 09:27
Tolga Cakir
tolgatc is on a distinguished road
    TrackData& td,
    const scalar dt,
    const label cellI,
    const scalar Re,
    const scalar mu,
    const scalar mass,
    const vector& Su,
    vector& dUTrans,
    scalar& Spu
) const
    Spu = dt*Feff.Sp();
    return Unew;
Fncp = ((0 0 0) 0)
Fncp = ((0 0 0) 0)
Fncp = ((0 0 0) 0)
Fncp = ((0 0 0) 0)
if Re > 1000:
        Cd = 0.424
    else:
dV = Vinf-V
Fnet = Fd
A = Fnet/mp
    const scalar dt,
    const scalar mass,
    const scalar Re,
    const scalar muc
) const
    return value;
    if (Re > 1000.0)
        return 0.424*Re;
    else
With regard to the sphere drag contribution in OpenFOAM I think I now understand what the 'value.Sp() = mass*0.75*muc*CdRe(Re)/(p.rho()*sqr(p.d()));' means.
So start with particle assuming only a drag force acting on it, then Newton's second law is:
m_{p}\frac{dV_p}{dt}= F_d = C_d\frac{1}{2}\rho_f(V-V_p)^2 A
In this m_p represents the particle mass, which is volume of a sphere times density of particle, V_p is particle velocity and V is surrounding velocity and A is reference area which is the area of a circle in this case. Now divide left and right by the mass, so what we are left with is the expression for the drag force per unit mass:
\frac{F_D}{m_{p}}= C_d\frac{3}{4}\frac{\rho_f}{\rho_p}\frac{(V-V_p)^2}{d}
Now we rewrite the right hand side slightly by multiplying and dividing by viscosity and diameter:
\frac{F_D}{m_{p}}= C_d\frac{3}{4}\frac{\rho_f}{\rho_p}\frac{(V-V_p)^2}{d}\frac{\mu_f d}{\mu_f d}=\frac{3}{4}\frac{\mu_f}{\rho_p}\frac{1}{d^2}(V-V_p)\frac{\rho_f(V-V_p)d}{\mu_f}C_D=\frac{3}{4}\frac{\mu_f}{\rho_p}\frac{1}{d^2} (V-V_p) Re C_d
Now looking at the definition of Sp we see that it is defined as the force per unit velocity, because in the files for Sp and Su it says F=Sp(U-Up)+Su.
So if we factour out (V-V_p) and again multiply by the particle velocity we have obtained the exact same expression as the one in the code.
I hope this helps to understand where it comes from.
alvora, freezar, ArneLa and 2 others like this.
tolgatc is offline   Reply With Quote
Old   July 23, 2020, 06:39
Arne Lampmann
ArneLa is on a distinguished road
Thanks for the nice derivation. It was very helpful.
However, I struggle with the continuous flow velocity, which seems not to be taken into account in OF.
When I have a look at the implementation of the Particle-Reynolds Number there is no Uc_
    // Reynolds number
     const scalar Re = this->Re(U_, d_, rhoc_, muc_);
and I also see no Uc_ taken into account for the UIntegrator
ArneLa is offline   Reply With Quote
Old   July 23, 2020, 08:06
Arne Lampmann
Just had a look at the definition of the Reynolds number function in OF and everything is fine and accordingly to the derivation:
inline Foam::scalar Foam::KinematicParcel<ParcelType>::Re
     const vector& U,
     const scalar d,
     const scalar rhoc,
     const scalar muc
 ) const
     return rhoc*mag(U - Uc_)*d/(muc + ROOTVSMALL);
lukasf likes this.
kinematic cloud, parcel, positions
Postdoc position available on hybrid CFD/Molecular-Dynamics using OpenFOAM jasonreese OpenFOAM 0 October 13, 2009 18:19
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Postdoctoral position using OpenFOAM schmidt_d OpenFOAM 1 February 24, 2009 05:01
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
