May 29, 2016, 19:06 |
#21 |
anonymous
Rep Power: 10 |
Thanks alexeym . Yes, I used iso-surface to get my interfaces, but I did not use threshold filter, I will try later.
This was the base case study before moving to more complex problem. My next step is to implement Rosenborck-Wanner method in my case. I found a file rosenbock34.C, which is available in ODE solvers but it is for ODE. Can you suggest how to use the method using PDE? It seems to me that I need to start from scratch. |
May 31, 2016, 06:09 |
#22 |
What do you mean by "how to use the method using PDE?"? I think before starting "from scratch" you need to formulate your problem a little bit clearer.
May 31, 2016, 10:40 |
#23 |
anonymous
Rep Power: 10 |
I am using a PDE model, we know that the system is stiff and would like to use RosenBrock method to solve numerically. See simplified version of attached PDE.
May 31, 2016, 11:28 |
#24 |
Guess, you would like to use mentioned method for time stepping? Well, any way it seems you have to start from scratch.
May 31, 2016, 11:34 |
#25 |
anonymous
Rep Power: 10 |
Thanks for all your help.
July 24, 2019, 17:59 |
#26 |
FaRa
Rep Power: 7 |
@cute How could you manage to show the semi-spheres like that? Can you please explain in details?
By the way, thanks to both of you. It was a very helpful conversation. |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
OpenFoam - Vof verification with standard cases | P Sharma | OpenFOAM Running, Solving & CFD | 4 | December 1, 2014 01:25 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
OpenFOAM tests cases | cfdivan | OpenFOAM Installation | 2 | August 14, 2013 16:33 |
Convertation axisymmetric cases from Fluent to OpenFOAM | Svensson | OpenFOAM | 0 | April 19, 2011 07:08 |
