implicit - (fvc::grad(U) & fvc::grad(muEff))
Old   May 13, 2016, 19:15
Default implicit - (fvc::grad(U) & fvc::grad(muEff))
Kareem Abdelshafy
Kareem Abdelshafy is on a distinguished road
Hello Foamers
I am trying to model two phase flow (water and high vicious fluid ) inside a micro-channel. After dimensionless, the reynolds number becomes very low. as far as I know, if the diffusion term is solved fully explicit , a new time step constrain for the diffusion term becomes dx^2 *Re which is very small in my case.
In most multiphase solvers in openfoam , the diffusion term are treated semi-explicit ( - (fvc::grad(U) & fvc::grad(muEff)) is explicit) which constrain my time step to unpractical time step. Otherwise, if I increased the time step with even Co number < 0.1 , the solver diverge. The solver works fine, if I removed this term, but the result becomes unphysical.
My question. Is there any suggestions to increase the time step or make this term - (fvc::grad(U) & fvc::grad(muEff)) implicit in openFoam ?
Thanks a lot
Kareem Abdelshafy is offline   Reply With Quote
Old   August 20, 2016, 21:57
Kareem Abdelshafy
I managed to solve the problem. Adding these two terms in the UEqn enhanced the solution stability.
- fvm::laplacian(max(MuEff), U)
+ fvc::laplacian(max(MuEff), U)
Can anybody give a introduction of the term "point implicit" and 'line implicit' ? Tommy Chen Main CFD Forum 2 August 3, 2015 04:30
Implicit source term and porousInterFoam Andrea_85 OpenFOAM Programming & Development 0 August 30, 2013 05:30
Help. implicit discritization dearboy Main CFD Forum 0 November 25, 2010 22:46
how implicit is implicit? Joe cool Main CFD Forum 7 July 16, 2004 12:10
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 15:04
