Cannot use thermophysical properties in new boundary condition
Old   April 29, 2016, 08:53
Default Cannot use thermophysical properties in new boundary condition
TobM is on a distinguished road
I have tried to make a new boundary condition for temperature.
Solver: compressibleInterFoam
Version: 3.0.x
I want to use kappa (thermal diffusivity) to calculate the boundary value.
Everything works fine as long as I write a fix value in the equation.
However, when I try to use kappa from the thermophysical model I get an error message.
Obviously I miss s.th. I just don't know what and I am out of ideas.
.H and .C files are attached, options, files and error message are below:
EXE_INC = \
    -I$(FOAM_SOLVERS)/multiphase/compressibleInterFoam/twoPhaseMixtureThermo \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
    -ltwoPhaseMixtureThermo \
    -lcompressibleTurbulenceModels \
    -lcompressibleTransportModels \
    -ltwoPhaseMixture \
    -lfluidThermophysicalModels \
    -lturbulenceModels \
    -lspecie \
    -lfiniteVolume \
    -lmeshTools
simplifiedTransHeatFvPatchScalarField.C
LIB = $(FOAM_USER_LIBBIN)/libsimpilfiedTransientHeat
wmakeLnInclude: linking include files to ./lnInclude
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-3.0.x/applications/solvers/multiphase/compressibleInterFoam/twoPhaseMixtureThermo -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/TurbulenceModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/transportModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/transportModels/twoPhaseMixture/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c simplifiedTransHeatFvPatchScalarField.C -o Make/linux64GccDPInt32Opt/simplifiedTransHeatFvPatchScalarField.o
simplifiedTransHeatFvPatchScalarField.C: In member function ‘virtual void Foam::simplifiedTransHeatFvPatchScalarField::updateCoeffs()’:
simplifiedTransHeatFvPatchScalarField.C:176:24: error: request for member ‘kappa’ in ‘Foam::mixture’, which is of non-class type ‘Foam::twoPhaseMixtureThermo(const Foam::fvMesh&)’
       * exp((- mixture.kappa(patchi)*patch().deltaCoeffs()*t)
/opt/OpenFOAM/OpenFOAM-3.0.x/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/simplifiedTransHeatFvPatchScalarField.o' failed
make: *** [Make/linux64GccDPInt32Opt/simplifiedTransHeatFvPatchScalarField.o] Error 1
Kind regards
Tobi
TobM is offline   Reply With Quote
compressibleinterfoam, thermophysicalproperties
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 13:02
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
boundary condition and differenet constant properties for for two different region. alvora OpenFOAM 2 January 25, 2011 05:08
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
