Adding New phaseCompressible Turbulence Model
Like Tree2Likes
Old   November 16, 2016, 12:26
Hassan Kassem
hk318i is on a distinguished road
For anyone who may read this thread in the future, OpenFOAM foundation has adapted a similar approach. Unfortunately, this update is available only for OpenFOAM-dev but eventually, it will be part of the upcoming versions.
It is commit OpenFOAM-dev : 028617c30c68a66c00a3cda28e8706709f9f9e10
@HIKassem | HassanKassem.me
hk318i is offline   Reply With Quote
Old   November 16, 2016, 12:35
W. Schuyler Hinman
schuyler is on a distinguished road
Thanks Hassan,
I missed that function definition when I was copying over the functions from 2.3. Sometimes it takes a second set of eyes! Now I just have a floating point exception somewhere I've got to find haha. Hopefully, shouldn't be too hard.
Thanks again for your help!
Schuyler
hk318i likes this.
schuyler is offline   Reply With Quote
Old   November 17, 2016, 08:28
Mukesh Adlak
Adlak is on a distinguished road
Thanks for reply.
I have uploaded my files, please go through this. Yes it a CFD support version downloaded from following link :
http://www.cfdsupport.com/openfoam-in-box.html
it is OpenFoam in box based on openFoam 3.0.x
For compiling my turbulence model I followed the steps as given here:
http://hassankassem.me/posts/newturbulencemodel/
Adlak is offline   Reply With Quote
Old   November 17, 2016, 09:01
Hassan Kassem
You have a similar problem, the definition of one function is missing:
You called it at line 110.
volScalarField Ck() const;
Best wishes,
Hassan
Old   November 18, 2016, 05:34
Mukesh Adlak
Best wishes,
Hassan
Thanks for reply,
I will try to do what u said. But can u please tell me how can I learn to understand the OpenFoam codes ? can u please provide me some study references for that ?
Old   November 18, 2016, 08:18
Hassan Kassem
Originally Posted by Adlak View Post
Thanks for reply,
Actually, this problem is related to C++. There are many C++ online material and books. Regarding this problem you need to review C++ source files organization, usually at the end of any C++ book. Please check this link from C++ wikibooks [LINK]
Best wishes,
Hassan
Old   November 25, 2016, 00:26
Mukesh Adlak
Best wishes,
Hassan
Dear Hassan,
Still the problem is not solved. My turbulence model is compiled successfully but while running my case i am getting following error :
reactingFoam: symbol lookup error: /home/adlak/OpenFOAM/adlak-3.0.x-cfdsupport/platforms/linux64Gcc49DPInt32Opt/lib/libdynamicSmagorinsky.so: undefined symbol: _ZNK4Foam9LESModels18dynamicSmagorinskyINS_15EddyD iffusivityINS_18ThermalDiffusivityINS_27Compressib leTurbulenceModelINS_11fluidThermoEEEEEEEE2CkEv
I have uploaded my files.
Old   November 26, 2016, 11:35
Hassan Kassem
Dear Hassan,
Try this to find the missing link;
c++filt _ZNK4Foam9LESModels18dynamicSmagorinskyINS_15EddyDiffusivityINS_18ThermalDiffusivityINS_27CompressibleTurbulenceModelINS_11fluidThermoEEEEEEEE2CkEv
Old   March 18, 2019, 10:04
Jianrui Zeng
calf.Z is on a distinguished road
 Duplicate entry laminar in runtime selection table TurbulenceModel
 Duplicate entry LES in runtime selection table TurbulenceModel
Best wishes,
Hassan Kassem
I have also encountered this Duplicate entry problem. Have you solved it? Thank you.
calf.Z is offline   Reply With Quote
Old   January 14, 2020, 12:04
Default Still problems
  #30
Dhruv
TurbulentGuy is on a distinguished road
Hello Hassan
I read your blogpost and it helped me a lot. I am currently trying to implement a recent k-Omega SST model in OpenFOAM7. I obeyed all the instructions in the blogpost and read the previous posts in this thread but I am still facing the same "Unknown RAS Model" error.
I have not changed the original OpenFOAM repo on my device to keep it intact and I have written the name of the library correctly in controlDict.
Thanks
Dhruv
TurbulentGuy is offline   Reply With Quote
Old   February 12, 2020, 12:12
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
You maybe need to run wclean first. In case, it did not wok, I'm attaching here two examples which you can use for comparison.
Bw,
Hassan
Dear Hassan,
I copied your files and put them into phasecompressibleturbulencemodel folder. But it failed to be compiled. The error is in the following:
$ wmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file myphaseCompressibleTurbulenceModels.C
could not open file ThermalDiffusivity.H for source file myphaseCompressibleTurbulenceModels.C
could not open file EddyDiffusivity.H for source file myphaseCompressibleTurbulenceModels.C
could not open file laminar.H for source file myphaseCompressibleTurbulenceModels.C
could not open file RASModel.H for source file myphaseCompressibleTurbulenceModels.C
could not open file LESModel.H for source file myphaseCompressibleTurbulenceModels.C
$(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/OpenFOAM-5.x/applications/solvers/multiphase/twoPhaseEulerFoam/twoPhaseSystem/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/basic/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/specie/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/solidThermo/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/solidSpecie/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/finiteVolume/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/meshTools/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/applications/solvers/multiphase/twoPhaseEulerFoam/interfacialModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/incompressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/phaseCompressible/lnInclude @Make/mingw_w64GccDPInt32Opt/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -c myphaseCompressibleTurbulenceModels.C -o J:/blueCFD-Core-2017/ofuser-of5/applications/solvers/mytwoPhaseEulerFoam4/phaseCompressibleTurbulenceModels/Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o
myphaseCompressibleTurbulenceModels.C:32:10: fatal error: ThermalDiffusivity.H: No such file or directory
#include "ThermalDiffusivity.H"
compilation terminated.
make: *** [/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/rules/General/transform:26: Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o] Error 1
qi.yang@polimi.it is offline   Reply With Quote
Old   March 25, 2020, 07:43
amanda
sunjh is on a distinguished road
Originally Posted by TurbulentGuy View Post
Hello Hassan
Thanks
Dhruv
Hey Dhruv,
I'm facing the same problem. I'm not sure, if it becauses of Windows. Did you solve it?
sunjh is offline   Reply With Quote
Old   March 25, 2020, 08:10
kimy
Originally Posted by sunjh View Post
Hey Dhruv,
Hi, if you use linux there are no this problem.
Old   March 25, 2020, 08:54
amanda
Hi, is there any method to fix this problem on windows?
Old   March 25, 2020, 09:08
kimy
I also tried to ask this before. However, I found the method is available in linux. I gave up this issue. In my opinion, you'd better use linux-openfoam.
phasecompressible, phaseincompressible, tubulence model, turbulence, twophaseeulerfoam
Adding graviational acc. to turbulence model fertinaz OpenFOAM Programming & Development 6 December 12, 2020 01:04
chtMultiRegionSimpleFoam: strange error samiam1000 OpenFOAM Running, Solving & CFD 26 December 29, 2015 23:14
Turbulence model choice dave13 CFX 3 December 22, 2015 08:12
Compressible turbulence model issues 351Cleveland OpenFOAM 5 October 24, 2013 16:41
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 06:45
