adding density eqn"Mille and Poisson" in pisoFoam |
April 24, 2016, 05:11 |
CFD_Lovers
Rep Power: 11 |
Hi foamers!
as i wrote in Title, i want to add in calculation density based on Mille and Poisson in pisoFoam.C i want to caculate the density in each step as function of S and T (concentration and temperature) so how can i do this ? and "Mille and Poisson" is : rho==(rho/1000*(999.842594+6.793952e-2*T-(9.095290e-3*pow(T,2))+ (1.001685e-4*pow(T,3))-(1.120083e-6*pow(T,4))+(6.536336e-9*pow(T,5))+ S*(8.24493e-1-4.0899e-3*T+(7.6438e-5*pow(T,2))-(8.2467e-7*pow(T,3))+ (5.3875e-9*pow(T,4)))+(pow(S,1.5))*(-5.72466e-3+1.0227e-4*T-1.6546e-6*pow(T,2))+S*(4.8314e-4))) and rho is my density that is identified in transportperoperties and creatField.H when i compile the code the error message is : my_pisoFoam.C:81:96: error: no match for ‘operator==’ in ‘rho == Foam:perator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]((*(const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = double, Type2 = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = double]((*(const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::GeometricField<Type, PatchField, GeoMesh>&, const scalar&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::scalar = double]((* &4.83140000000000012590067877127353312971536070108 413696289e-4))))))))’ my_pisoFoam is the name of modified pisoFoam. any help would appreciated. all the bests |
April 28, 2016, 03:15 |
W.T
Rep Power: 14 |
Hi
You should use a "=" operator instead of "==" |
April 30, 2016, 03:57 |
CFD_Lovers
Rep Power: 11 |
Hi dybuk!
thank u very much, but i used this before and again i faced with the problem, i heard from someone that this problem come from dimensional agreement! for example rho has a different dimension from T ! do u know something about this ? thank u again |
