How to add Surface Tension in cavitatingFoam solver
Old   March 29, 2016, 14:24
Smile How to add Surface Tension in cavitatingFoam solver
Xin Tang
jamestangx is on a distinguished road
Dear Foamers,
I am new to OpenFoam and want to add surface tension to the cavitatingFoam solver. Is it possible to add surface tension in cavitatingFoam?
[Background]
I want to add surface tension term in cavitatingFoam solver to calculate collapsing cavitation (need compressible two phase solver). And I tried to implement surface tension according to interFoam solver. The new solver called cavitatingSTFoam is created and major files are attached. (The zip file of the whole solver exceeds the maxfilesize 195.3K, so I just upload the modified major files)
In interFoam.C, the immiscibleIncompressibleTwoPhaseMixture.H is included and the following code is used for surface tension term:
fvc::reconstruct
                    mixture.surfaceTensionForce()
                ) * mesh.magSf()
However, the cavitatingFoam solver uses a different model and include "incompressibleTwoPhaseMixture.H" which dose not have surfaceTensionForce().
I tried to use the same continuum method to model the surface tension and add it in UEqn.H of cavitatingFoam refer to the previous thread Plotting suface tension with interFoam. New problem pops up for "interface","alpha1" and reconstruct function in "UEqn.H".
error message for "interface"
createFields.H: In function ‘int main(int, char**)’:
createFields.H:78:44: error: ‘interface’ was not declared in this scope
         fvc::reconstruct((fvc::interpolate(interface.sigmaK())*fvc::snGrad(alphal))* mesh.magSf())
error message for "alpha1"
cavitatingSTFoam.C:100:55: error: ‘alpha1’ was not declared in this scope
  f = fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1);
error message for "reconstruct"
In file included from cavitatingSTFoam.C:86:0:
UEqn.H:39:14: error: no matching function for call to ‘reconstruct(Foam::tmp<Foam::Field<Foam::Vector<double> > >)’
UEqn.H:39:14: note: candidates are:
In file included from /opt/openfoam240/src/finiteVolume/lnInclude/fvcReconstruct.H:85:0,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvc.H:43,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from cavitatingSTFoam.C:35:
/opt/openfoam240/src/finiteVolume/lnInclude/fvcReconstruct.C:53:1: note: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::reconstruct(const Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>&)
 reconstruct
/opt/openfoam240/src/finiteVolume/lnInclude/fvcReconstruct.C:53:1: note:   template argument deduction/substitution failed:
UEqn.H:39:14: note:   ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ is not derived from ‘const Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>’
/opt/openfoam240/src/finiteVolume/lnInclude/fvcReconstruct.C:95:1: note: template<class Type> Foam::tmp<Foam::GeometricField<typename Foam::outerProduct<Foam::Vector<double>, Type>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::reconstruct(const Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> >&)
 reconstruct
/opt/openfoam240/src/finiteVolume/lnInclude/fvcReconstruct.C:95:1: note:   template argument deduction/substitution failed:
UEqn.H:39:14: note:   mismatched types ‘Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>’ and ‘Foam::Field<Foam::Vector<double> >’
UEqn.H:39:14: note:   ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> >’
Any ideas?
Thanks for your time,any help and advice is appreciated!
File Type: h UEqn.H (926 Bytes, 24 views)
jamestangx is offline   Reply With Quote
Old   April 6, 2016, 17:39
Default Surface Tension Added
Xin Tang
I finally added the surface tension term successfully by trial and error. I will share with everyone in case you met the same problem.
I included the following header files compared to OpenFoam 2.1 interFoam solver in my solver source code
// imported from interFoam 2.1
#include "interfaceProperties.H"
#include "twoPhaseMixture.H"
in createFields.H file, there is declarators for alphav, alphal. I don't know why it does not work with alpha1, however, when I change alpha1 ->alphal, the solver can be wmake sucessfully.
    incompressibleTwoPhaseMixture mixture(U, phi);
    volScalarField& alphav(mixture.alpha1());
    alphav.oldTime();
    volScalarField& alphal(mixture.alpha2());
Also in "creatFields.H", the following codes should be added. And call the function of interface from "interfaceProperties.H"
// surface tension force is the same to the previous thread plotting surface tension with interFoam
// Construct interface from alphal distribution
    interfaceProperties interface(alphal, U, mixture);
    volVectorField f
        IOobject
            "f",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
Finally, you can also add f=fvc::reconstruct((fvc::interpolate(interface.sig maK())*fvc::snGrad(alphal))* mesh.magSf()) in the source file for further postprocessing. And the following figure are the final results of surface tension magnitude and tangent vector in the slice view of the cavitation in water using tecplot 360.
Help!! customize surface tension term in interFoam w051cxw OpenFOAM Programming & Development 5 February 12, 2016 15:56
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? SJSW Fluent Multiphase 2 November 18, 2014 05:15
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 13:19
