How to access a new defined fields in turbulence model code
Old   March 21, 2016, 07:07
Default How to access a new defined fields in turbulence model code
Xinguang Wang
JasonWang3 is on a distinguished road
Dear All
In my program, I defined a new fields in the ''creatfields.H'', as:
volScalarField UConvec1
IOobject
"UConvec1",
runTime.timeName(),
mesh
mesh,
dimensionedScalar
"UConvec1",
dimensionSet(1, -2, -2, 0, 0, 0, 0),
0.0
UConvec1 is calculated in the main program and stored the convection term in the previous time step, and will renewed at the end of the main program, and also used when dealing with the momentum equation.
In the turbulence mode code, such as kEpsilon.C, I need to access this field, here is my question, How can I access this field when coding in the turbulence model?
regards,
Xinguang
JasonWang3 is offline   Reply With Quote
Old   March 24, 2016, 15:35
Hassan Kassem
hk318i is on a distinguished road
lookupObject maybe the solution
check this
http://www.cfd-online.com/Forums/ope...-scalar-2.html
hk318i is offline   Reply With Quote
Access turbulence model in coded functionobjectlibs eelcovv OpenFOAM Programming & Development 6 December 1, 2018 19:43
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 12:25
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 06:45
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 12:31
