PMM test in OpenFOAM
Old   March 12, 2016, 11:51
Default PMM test in OpenFOAM
Thaw Tar's Avatar
Thaw Tar
Thaw Tar is on a distinguished road
Hi everyone,
I want to do the simulation of planar motion mechanism (PMM) test for an autonomous underwater vehicle (AUV) using OpenFOAM.
I want to simulate the flow field around AUV which is fully submerged (single phase flow) using PMM procedure. I want to give the forced oscillations of yaw motion to the AUV for certain periods to create the sine wave motion using dynamic mesh in OpenFOAM.
I searched for it and found Ship Design Analysis (SDA) using solid body motion. But it has only roll, heave and pitch motions. Thus, I want to know whether I can use this technique, by changing the coordinate system of the AUV to create yaw motion instead of roll. I am also not clear about whether I can use SDA for single phase flows.
Or do I need to re-create another SDA that has the capability of doing yaw motion by myself? I am not good at OpenFOAM programming.
Thanks in advance,
Thaw Tar
Thaw Tar is offline   Reply With Quote
Old   February 14, 2022, 02:55
Shamjad
9034 is on a distinguished road
Hii Thaw Tar..
Am also working on the same problem. were you able to solve this
9034 is offline   Reply With Quote
Old   June 6, 2024, 19:03
ozi
Ph.D.(c) Oğuzhan KIRIKBAŞ
ozi is on a distinguished road
Did you get any progress?
ozi is offline   Reply With Quote
dynamic mesh, openfoam, ship design analysis
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
Cluster test with openfoam clo OpenFOAM Running, Solving & CFD 7 February 23, 2009 00:44
