Degassing Boundary Condition
Like Tree5Likes
Old   March 22, 2016, 07:01
Timucin Kislak
Lokati is on a distinguished road
so it is like this:
valueFraction()=
sqr(n) = n*n
so n*n leads to a valueFraction=(1 0 0 1 0 1) .
I am really bad in mathematics so here is my question?
If you multiply the normal vectors n*n , how does it change the valueFraction to (1 0 0 1 0 1)?? The valueFraction is a tensor, but the normal vector is a vector.
Best regards,
Timucin
Lokati is offline   Reply With Quote
Old   March 22, 2016, 08:21
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by Lokati View Post
so it is like this:
valueFraction()=
sqr(n) = n*n
Best regards,
Timucin
Hi Timucin,
It seems that you are a bit confused.
Some info that might help clarify things for you:
n*n does not equal (1 0 0 1 0 1).
(1 0 0 1 0 1) is the identity tensor in symmetric tensor form i.e. (xx xy xz yy yz zz).
valueFraction is a symmetric tensor not a tensor, hence it has 6 independent components, not 9.
If the normal vector is (nx ny nz) then n*n (an outer product) is a symmetric tensor: (nx*nx nx*ny nx*nz ny*ny ny*nz nz*nz).
To set valueFraction to (1 0 0 1 0 1):
valueFraction() = symmTensor(1, 0, 0, 1, 0, 1);
I also suggest you read the other threads on the directionMixed boundary condition.
Philip
bigphil is offline   Reply With Quote
Old   April 4, 2016, 05:33
Timucin Kislak
Hi Phil,
how can (nx*nx nx*ny nx*nz ny*ny ny*nz nz*nz) set the normal component to fixedValue and the tangential components to fixedGradient?
Best regards,
Timucin
Old   April 4, 2016, 08:26
Timucin Kislak
Hi Phil,
do yo know how i could directly change the value of the velocity neighbour cells? I want to fix the neighbour cells to Zero.
Accessing to a neigbour value is not the problem...but how can i directly change the value?
Best regards,
Timucin
Old   April 21, 2016, 11:18
jp279
jp279 is on a distinguished road
Send a message via Skype™ to jp279
Hi Lokati,
I am also trying degassing outlet in bubble column. I don't have condition on alpha as you, so can simply use Slip BC for the liquid and pressureInletOutletVelocity BC for the gas at the degassing patch? Isn't combination of these two BCs indeed the degassing BC?
jp279 is offline   Reply With Quote
Old   April 21, 2016, 14:45
Timucin Kislak
Hi Jigar,
i understand you're problem, but it is different from mine, because you do not have alpha. I do not know how you can specify the BC for you're problem.
My advice is that you just make a case with openFOAM and try out some things.
This thread is very good for you i think, but i really don't know more about this BC.
Best regards
Timucin
Old   April 21, 2016, 15:37
jp279
Dear Lokati,
Thanks for the reply. I'll make a test case and will get back with its details as well as the results (if any).
Jigar
boundary, degas, interfoam, openfoam, outlet
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
